تساقط القمح داخل الساقية (Elevator) – الأسباب والحلول
مشاركات: 9267
𝐑𝐚𝐢𝐧𝐢𝐧𝐠 𝐨𝐟 𝐖𝐡𝐞𝐚𝐭 𝐢𝐧 𝐄𝐥𝐞𝐯𝐚𝐭𝐨𝐫 – 𝐂𝐚𝐮𝐬𝐞𝐬 𝐚𝐧𝐝 𝐒𝐨𝐥𝐮𝐭𝐢𝐨𝐧𝐬
“Raining” in an elevator refers to wheat falling inside the elevator casing during operation, often due to mechanical issues or changes in wheat properties. Proper adjustment of feed rate and regular maintenance can minimize product loss and ensure smooth grain handling.
𝐏𝐨𝐬𝐬𝐢𝐛𝐥𝐞 𝐑𝐞𝐚𝐬𝐨𝐧𝐬:
• Change in wheat density (due to moisture variation or different wheat varieties) causing improper filling and discharge of buckets.
• Overloading of elevator buckets leading to spillage at the elevator head.
• Worn or damaged buckets that cannot properly retain the wheat.
• Improper belt speed or misalignment resulting in uneven discharge.
• Choked or restricted outlet causing wheat to fall back inside the elevator casing.
• Loose bucket bolts or improper bucket spacing leading to grain leakage.
𝐒𝐨𝐥𝐮𝐭𝐢𝐨𝐧𝐬:
• Adjust feed rate according to wheat density and flow properties.
• Maintain proper bucket loading to avoid overfilling.
• Inspect and replace damaged buckets when required.
• Ensure correct belt alignment and tension.
• Clean and maintain outlet chutes to prevent blockage.
• Regularly tighten bucket bolts and inspect elevator conditions.
https://www.linkedin.com/mwlite/feed/posts/husnain-hasan-4139471b5_wheatmilling-flourmill-grainelevator-share-7436421151448424448-u_jX?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=%F0%9D%90%91%F0%9D%90%9A%F0%9D%90%A2%F0%9D%90%A7%F0%9D%90%A2%F0%9D%90%A7%F0%9D%90%A0%20%F0%9D%90%A8%F0%9D%90%9F%20%F0%9D%90%96%F0%9D%90%A1%F0%9D%90%9E%F0%9D%90%9A%F0%9D%90%AD%20%F0%9D%90%A2%F0%9D%90%A7%20%F0%9D%90%84%F0%9D%90%A5%F0%9D%90%9E%F0%9D%90%AF%F0%9D%90%9A%F0%9D%90%AD%F0%9D%90%A8%F0%9D%90%AB%20%E2%80%93%20%F0%9D%90%82%F0%9D%90%9A%F0%9D%90%AE%F0%9D%90%AC%F0%9D%90%9E%F0%9D%90%AC%20%F0%9D%90%9A%F0%9D%90%A7%F0%9D%90%9D%20%F0%9D%90%92%F0%9D%90%A8%F0%9D%90%A5%F0%9D%90%AE%F0%9D%90%AD%F0%9D%90%A2%F0%9D%90%A8%F0%9D%90%A7%F0%9D%90%AC%0A%0A%E2%80%9CRaining%E2%80%9D%20in%20an,inspect%20elevator%20conditions.
مصطلح “التساقط” داخل الساقية يشير إلى سقوط القمح داخل جسم الساقية أثناء التشغيل، وغالبًا ما يحدث نتيجة مشاكل ميكانيكية أو تغيرات في خصائص القمح. إن الضبط الصحيح لمعدل التغذية وإجراء الصيانة الدورية يمكن أن يقللا من فاقد المنتج ويضمنا سلاسة تداول الحبوب.
الأسباب المحتملة:
• تغير كثافة القمح (بسبب اختلاف نسبة الرطوبة أو اختلاف أصناف القمح) مما يؤدي إلى عدم امتلاء القواديس (Buckets) وتفريغها بشكل صحيح.
• تحميل زائد على جيوب الساقية مما يؤدي إلى انسكاب القمح عند رأس الساقية (Elevator Head).
• تآكل أو تلف القواديس بحيث لا تتمكن من الاحتفاظ بالقمح بشكل جيد.
• سرعة سير/تونس غير مناسبة أو عدم محاذاة السير/تونس (Belt Misalignment) مما يؤدي إلى تفريغ غير منتظم.
• انسداد أو تضييق في مخرج الساقية (Outlet) مما يسبب رجوع القمح وسقوطه داخل جسم الساقية.
• ارتخاء مسامير تثبيت القواديس أو عدم انتظام المسافات بينها مما يؤدي إلى تسريب الحبوب.
الحلول:
• ضبط معدل التغذية بما يتناسب مع كثافة القمح وخصائص تدفقه.
• الحفاظ على تحميل مناسب للجيوب لتجنب الامتلاء الزائد.
• فحص القواديس واستبدال التالف منها عند الحاجة.
• التأكد من المحاذاة الصحيحة للسير/تونس وضبط الشد (Tension) بشكل مناسب.
• تنظيف وصيانة مجاري التفريغ (Chutes) لمنع حدوث انسدادات.
• الربط الدوري لمسامير القواديس وفحص حالة الساقية بشكل منتظم.
مشاركات: 9267
Re: تساقط القمح داخل الساقية (Elevator) – الأسباب والحلول
بالاضافة لما هو أعلاه :
ضبط لقاف الساقية
