Diablo 4 Patch 3.1.1 Farming Tips by U4GM
Blustery
مشاركات: 3
اشترك في: الخميس يوليو 16, 2026 9:53 am
مشاركة بواسطة Blustery »
Season 14 Mythic farming changed in a quiet but useful way with Patch 3.1.1. It hasn't turned rare gear into free loot, and you can still go through a rough stretch without seeing the drop you want. What has changed is the value of making good decisions. Players who choose efficient encounters, protect their boss materials, and farm with a clear target are getting more chances at useful Diablo 4 Items than those who simply force the hardest content available. That distinction matters. A farming route should feel repeatable, not like a test of patience after every summon. If a boss takes too long, drains your potions, or regularly sends you back to town, the higher difficulty probably isn't paying for itself.
Clear Speed Matters More Than Bragging Rights
Torment 10 appears to be a comfortable farming point for many established builds after the patch. It's demanding enough to offer worthwhile rewards, but it doesn't punish every small mistake the way Torment 12 can. Of course, your ideal setting depends on your gear. Don't treat Torment 10 as a rule carved in stone. Use it as a benchmark. Time several kills, then compare the results with a higher or lower tier. You'll quickly notice whether the extra difficulty is helping. A three-minute kill on Torment 12 may look impressive, but three smooth kills on a lower tier create more loot rolls in roughly the same window. That's the number that counts. Your build also needs more than damage on a training dummy. Movement speed, resource recovery, defensive uptime, and quick transitions between phases often save more time than another small increase to peak damage.
Keep Your Key Supply Moving
Players often wreck their own farming session by spending every premium key as soon as it drops. It's tempting. The better approach is to keep part of your supply in reserve and feed it through a steady boss loop. Start with encounters that use cheaper or smaller keys. Those fights can provide crafting materials, replacement keys, and the resources needed to create Superior or Greater Keys. Once you've built a healthy stock, move into the more expensive summons without emptying the cupboard. This makes bad luck easier to absorb. If five Greater Boss runs produce nothing exciting, you'll still have a route back into the cycle instead of being forced to rebuild from zero. Stash space matters here too. Sort summoning materials before the session begins, clear out old gear, and decide what you'll salvage or sell. Spending ten minutes comparing weak drops after every run breaks the rhythm more than most players realise.
Farm the Boss That Can Drop What You Need
Patch 3.1.1 makes targeted boss farming feel more worthwhile, so check the relevant loot pool before committing your best keys. "Any Mythic will do" sounds fine until you've burned an evening on a boss that can't reliably supply the slot your build is missing. If you need a specific weapon, helm, or chest piece, put the associated encounter at the centre of your route. Greater Bosses remain the main attraction because their reward potential tends to justify the preparation, particularly when a run gives back keys or useful materials. That doesn't mean every other activity is worthless. Nemesis Layers, Tributes, and Charms can still fit into normal progression, but they're less convincing as the backbone of a dedicated Mythic hunt. Run them when they overlap with another goal. Don't pour scarce materials into them just because they carry a seasonal label.
Use Seasonal Tasks Without Slowing Down
Gift of the Tree events and Whisper objectives are best treated as bonuses attached to a route you were already going to run. Chasing an awkward objective across the map for one cache can cost more time than it saves. On the other hand, completing nearby Whispers while gathering boss resources is almost free value. The caches help with gold, crafting supplies, and materials that support the next round of summons. This is also where practical build management comes in. Keep one farming setup ready rather than changing skills and gear between every activity. Constant enchanting, rerolling, and tempering can eat through your savings fast, especially when a promising Mythic forces you to rebuild around it. Pick upgrades carefully. A small gain isn't always worth millions of gold, and an item sitting unused in the stash isn't improving your clear speed.
Final Thoughts
The strongest Season 14 strategy isn't complicated: fight at a difficulty you can clear quickly, build keys through cheaper encounters, and spend premium resources on bosses tied to the gear you actually need. Track results over a proper sample of runs rather than judging the patch after two unlucky summons. You'll still hit dry spells, but a sustainable loop gives you more attempts and wastes less time. It also leaves room for upgrades when something good finally lands. Keep enough materials for another round, maintain a reserve of cheap D4 Gold for rerolls and build changes, and avoid pushing a higher Torment tier merely because your character can survive it. Reliable kills beat slow, messy victories, and that steady pace is what turns Mythic farming from a gamble into a workable endgame routine.
