طفرة الفرن اثناء عملية الخبز تكون بشكل أساسي بسبب تمدد الغازات المحبوسة داخل العجين أثناء عملية الخبز
The dough oven rise is primarily caused by the expansion of gases trapped within the dough during the baking process. 👇
تحدث طفرة الخبز / طفرة الفرن اى ما يعنى ارتفاع وزيادة حجم الخبز داخل الفرن اثناء عملية الخبز بشكل أساسي بسبب تمدد الغازات المحبوسة داخل العجين أثناء عملية الخبز.
1. Carbon Dioxide:
· Generated by yeast during both aerobic and anaerobic fermentation of glucose in the dough.
· Carbon dioxide is the primary gas responsible for the dough's rise during baking, especially during the early stages of oven spring.
· Solubility in dough: At proof temperatures (32-38°C), carbon dioxide is soluble in water to about 1.0 g/kg.
· Temperature Profile: The critical temperature range for oven spring and the expansion of CO2 is typically between 40°C to 60°C . During this phase, the gas bubbles expand, resulting in the dramatic rise of the dough, creating the desired volume and open crumb structure in the bread.
2. Ethanol :
· Generated by yeast during the anaerobic fermentation of glucose in the dough.
· Equal molar quantities of ethanol and carbon dioxide are produced during anaerobic fermentation.
· Ethanol is readily soluble in water and organic solvents.
· Boiling point: 78.4°C.
· Temperature Profile: Ethanol contributes to the sudden oven spring early in the baking process. As the dough temperature approaches 70°C, its vaporization rate increases rapidly, maintaining bubble pressure during later stages of baking.
3. Water (Steam):
· Water is present is released during the baking process as steam.
· Water boils at 100°C, and steam is released later into the baking process.
· Steam plays a crucial role in oven spring, maintaining pressure inside the delicate gas bubbles towards the later stages of baking.
· Steam generation contributes to the breaking of gas bubbles during the foam to sponge conversion, allowing gases to escape and creating a more resilient bread structure.
· Temperature Profile: Steam is released into the dough as the oven temperature reaches or exceeds 100°C . Its influence continues throughout the baking process.
4. Nitrogen :
· Present in the air and entrained during mixing.
· Oxygen is used up by yeast during aerobic fermentation, leaving nitrogen in the bubbles.
· Nitrogen expands as the bread temperature rises but has a less significant contribution to bubble expansion compared to the gases that come out of solution.
· Temperature Profile: Nitrogen expansion takes place gradually as the dough temperature increases throughout the baking process.
👉 Temperature Profile Summary:
· Early Oven Spring (40°C to 60°C ): Carbon dioxide expansion is significant, causing the dough to rise dramatically.
· Mid-to-Late Baking (70°C to 100°C): Ethanol vaporization rate increases rapidly as the dough temperature approaches 70°C. Steam is released as the oven temperature reaches or exceeds 100°C, maintaining pressure in the gas bubbles during later stages of baking.
#breadmaking #baking #Grainar
https://www.linkedin.com/posts/dimitrios-argyriou-1a38251b6_gas-expansion-in-baking-activity-7087276888485732352-H1Dc?utm_source=share&utm_medium=member_desktop
1. Carbon Dioxide:
1. ثاني أكسيد الكربون:
· الناتجة عن الخميرة أثناء التخمير الهوائي واللاهوائي للجلوكوز في العجين.
· ثاني أكسيد الكربون هو الغاز الأساسي المسؤول عن ارتفاع العجين أثناء الخبز ، خاصة خلال المراحل المبكرة من طفرة الفرن.
· الذوبان في العجين: عند درجات حرارة مثبتة (32-38 درجة مئوية) ، يكون ثاني أكسيد الكربون قابلا للذوبان في الماء إلى حوالي 1.0 جم / كجم.
· ملف درجة الحرارة: يتراوح نطاق درجة الحرارة الحرجة لطفرة الفرن وتمدد CO2 عادة بين 40 درجة مئوية إلى 60 درجة مئوية. خلال هذه المرحلة ، تتوسع فقاعات الغاز ، مما يؤدي إلى الارتفاع الكبير للعجين ، مما يخلق الحجم المطلوب وهيكل الفتات المفتوح في الخبز.
2. Ethanol :
2. الإيثانول :
· الناتجة عن الخميرة أثناء التخمير اللاهوائي للجلوكوز في العجين.
· يتم إنتاج كميات مولية متساوية من الإيثانول وثاني أكسيد الكربون أثناء التخمير اللاهوائي.
· الإيثانول قابل للذوبان بسهولة في الماء والمذيبات العضوية.
· نقطة الغليان: 78.4 درجة مئوية.
· ملف درجة الحرارة: يساهم الإيثانول في طفرة الفرن المفاجئ في وقت مبكر من عملية الخبز. مع اقتراب درجة حرارة العجين من 70 درجة مئوية ، يزداد معدل تبخيره بسرعة ، مما يحافظ على ضغط الفقاعات خلال المراحل اللاحقة من الخبز.
3. Water (Steam):
3. الماء (البخار):
· يتم إطلاق الماء أثناء عملية الخبز كبخار.
· يغلي الماء عند 100 درجة مئوية ، ويتم إطلاق البخار لاحقا في عملية الخبز.
· يلعب البخار دورا مهما في طفرة الفرن ، حيث يحافظ على الضغط داخل فقاعات الغاز الرقيقة نحو المراحل اللاحقة من الخبز.
· يساهم توليد البخار في كسر فقاعات الغاز أثناء تحويل الرغوة إلى إسفنجة ، مما يسمح للغازات بالهروب وإنشاء هيكل خبز أكثر مرونة.
· ملف درجة الحرارة: يتم إطلاق البخار في العجين عندما تصل درجة حرارة الفرن إلى 100 درجة مئوية أو تتجاوزها. يستمر تأثيره طوال عملية الخبز
4. Nitrogen :
4. النيتروجين
: · موجود في الهواء ومحبوس أثناء الخلط.
· يتم استخدام الأكسجين بواسطة الخميرة أثناء التخمير الهوائي ، تاركا النيتروجين في الفقاعات.
· يتمدد النيتروجين مع ارتفاع درجة حرارة الخبز ولكن له مساهمة أقل أهمية في تمدد الفقاعة مقارنة بالغازات التي تخرج من المحلول.
· ملف درجة الحرارة: يحدث تمدد النيتروجين تدريجيا مع زيادة درجة حرارة العجين طوال عملية الخبز.
👉 ملخص ملف تعريف درجة الحرارة:
· طفرة الفرن المبكر (40 درجة مئوية إلى 60 درجة مئوية): تمدد ثاني أكسيد الكربون مهم ، مما يتسبب في ارتفاع العجين بشكل كبير.
· الخبز من منتصف إلى أواخر (70 درجة مئوية إلى 100 درجة مئوية): يزداد معدل تبخير الإيثانول بسرعة مع اقتراب درجة حرارة العجين من 70 درجة مئوية. يتم إطلاق البخار عندما تصل درجة حرارة الفرن إلى 100 درجة مئوية أو تتجاوزها ، مما يحافظ على الضغط في فقاعات الغاز خلال المراحل اللاحقة من الخبز.
رابط تحميل الملف
https://media.licdn.com/dms/document/media/D4D1FAQH53wM_QzWO4A/feedshare-document-pdf-analyzed/0/1689737585599?e=1692230400&v=beta&t=AR2QgXiyRPvYHenzcuFuYR6bmgGTxwU5H9TU2PxPYH8
