📊 Reduction System Optimization: C1A & C2 in Flour Milling
In modern wheat milling, the reduction system plays a critical role in determining flour quality, extraction rate, and overall plant efficiency. Among these stages, C1A and C2 are highly sensitive passages that directly impact final product performance.
🔹 C1A (First Reduction Passage)
C1A handles purified semolina from the break system.
✔️ Target Extraction: 8% – 12%
✔️ Grinding Objective: Fine and uniform particle size
✔️ Key Quality Impact:
Improves flour whiteness
Controls ash content
Ensures smooth granulation
👉 Proper roll gap and differential are essential to avoid over-grinding or bran contamination.
🔹 C2 (Second Reduction Passage)
C2 processes stock from C1A and remaining middlings.
✔️ Target Extraction: 10% – 15%
✔️ Grinding Objective: Further size reduction with minimal starch damage
Enhances flour consistency
Maintains protein quality
Balances extraction vs. quality
👉 Overloading C2 can increase starch damage and reduce flour stability.
📈 Overall Impact on Milling Performance
✔️ Total Reduction Contribution: ~45% – 55% of flour yield
✔️ Direct influence on:
Flour color (whiteness)
Ash level control
Dough strength & baking performance
⚙️ Operational Best Practices
✅ Maintain proper roll surface (smooth rolls condition)
✅ Optimize feed rate and roll pressure
✅ Ensure effective sifting after each passage
✅ Monitor stock flow balance between C1A & C2
💡 Conclusion
Efficient control of C1A and C2 reduction passages ensures a balance between maximum extraction and premium flour quality. Small adjustments in these stages can significantly improve overall mill performance.
https://www.linkedin.com/mwlite/feed/posts/nadeem-abbas-504b18295_flourmilling-wheatmilling-millingprocess-activity-7448664145102524416-0v3_#:~:text=%F0%9F%93%8A%20Reduction%20System%20Optimization,overall%20mill%20performance.
📊 تحسين نظام التنعيمات و الاختزال/مراحل السيهات (Reduction System): دراسة مرحلتي C1A وC2 في طحن الدقيق
في صناعة طحن القمح الحديثة، يلعب "نظام التنعيمات و الاختزال/مراحل السيهات" دوراً محورياً في تحديد جودة الدقيق، ونسبة الاستخراج، والكفاءة التشغيلية الكلية للمطحن. وتُعد المرحلتان C1A وC2 من أكثر مراحل الطحن حساسية، حيث تؤثران بشكل مباشر على أداء المنتج النهائي.
🔹 مرحلة C1A (مرحلة التنعيم الأولى أ)
تتعامل مرحلة C1A مع السيمولينا (السميد) النظيف النقى القادم من نظام الدش (Break System).
معدل الاستخراج المستهدف: 8% – 12%.
الهدف من الطحن: الحصول على حبيبات دقيق دقيقة وذات أحجام متجانسة.
التأثير الرئيسي على الجودة:
تحسين بياض الدقيق.
التحكم في نسبة الرماد (Ash Content).
ضمان نعومة وتجانس حبيبات الدقيق (Granulation).
> تنبيه: الضبط الدقيق للمسافة/الجاب بين درافيل الطحن (Roll gap) ونسبة السرعة بينها (Differential) أمر ضروري لتجنب الطحن الزائد أو اختلاط الدقيق بالنخالة.
🔹 مرحلة C2 (مرحلة التنعيم الثانية)
تقوم مرحلة C2 بمعالجة النواتج القادمة من مرحلة C1A وبقايا المتوسطات (Middlings/النخالة الناعمة).
معدل الاستخراج المستهدف: 10% – 15%.
الهدف من الطحن: تقليل حجم الجزيئات بشكل أكبر مع تقليل "تحطم النشا" (Starch damage) إلى أدنى حد ممكن.
تعزيز قوام الدقيق وثبات خصائصه.
الحفاظ على جودة البروتين.
تحقيق التوازن المثالي بين نسبة الاستخراج والجودة.
> تنبيه: التحميل الزائد على مرحلة C2 قد يؤدي إلى زيادة تحطم النشا، مما يقلل من استقرار جودة الدقيق أثناء الخبز.
📈 التأثير الكلي على أداء المطحن
المساهمة الإجمالية في نظام التنعيمات و الاختزال/مراحل السيهات: تُشكل هاتان المرحلتان حوالي 45% – 55% من إجمالي إنتاج الدقيق.
التأثير المباشر على:
لون الدقيق (درجة البياض).
التحكم في نسبة الرماد.
قوة العجين وأداء الخبز.
⚙️ أفضل الممارسات التشغيلية
✅ الحفاظ على حالة أسطح الدرافيل (ضمان بقاء الدرافيل الملساء في حالة ممتازة).
✅ تحسين معدل التغذية وضغط الدرافيل.
✅ ضمان كفاءة عملية النخل بعد كل مرحلة طحن.
✅ مراقبة توازن تدفق المنتج بين المرحلتين C1A وC2.
💡 إن التحكم الفعال في مرحلتي التنعيم C1A وC2 يضمن تحقيق التوازن الدقيق بين الحصول على أقصى نسبة استخراج ممكنة وبين إنتاج دقيق عالي الجودة. إن إجراء تعديلات طفيفة ومدروسة في هاتين المرحلتين يمكن أن يؤدي إلى تحسين ملحوظ في الأداء العام للمطحن.
- مشاركات: 9290
