Physical and chemical contamination
عبد الرحمن الجارحي
عضو فعال
عضو فعال
مشاركات: 478
اشترك في: الجمعة مايو 04, 2018 1:00 am
مشاركة بواسطة عبد الرحمن الجارحي »
Protect unwrapped food by
covering it or keeping it in suitable
display equipment.
It is not necessary to provide
covers for unwrapped whole fruit or
vegetables. However, you should
keep these foods away from ready
to eat foods
why
This helps to protect the food from:
• objects falling into the food e.g. hairs
• people touching the food or sneezing or
coughing over it
• pests such as flies
• cross-contamination
عبد الرحمن الجارحي
عضو فعال
عضو فعال
مشاركات: 478
Re: Physical and chemical contamination
Always clear and clean as you
go and take care to throw away
packaging, string, etc, as soon as
you remove it.
why
Keeping surfaces clear and clean will help
prevent objects getting into food, as well as
preventing the spread of bacteria.
عبد الرحمن الجارحي
عضو فعال
عضو فعال
مشاركات: 478
Follow the manufacturer’s
instructions on how to use and
store cleaning chemicals.
Store cleaning chemicals separately
from food and make sure they are
clearly labelled.
why
This is to prevent these chemicals getting into food.
عبد الرحمن الجارحي
عضو فعال
عضو فعال
مشاركات: 478
Make sure you control pests
effectivel
why
This is to prevent bacteria from spreading and stop damage
to food e.g. gnawed packets.
عبد الرحمن الجارحي
عضو فعال
عضو فعال
مشاركات: 478
Make sure that any chemicals you
use to control pests are used and
stored in the correct way and clearly
labelled.
why
