نشاط الألفا-أميليز ... رقم السقوط Falling Number Test
مرسل: الأحد إبريل 13, 2025 5:21 pm
𝘼𝙡𝙥𝙝𝙖-𝘼𝙢𝙮𝙡𝙖𝙨𝙚 𝘼𝙘𝙩𝙞𝙫𝙞𝙩𝙮: 𝙏𝙝𝙚 𝙁𝙖𝙡𝙡𝙞𝙣𝙜 𝙉𝙪𝙢𝙗𝙚𝙧
As we know, alpha-amylase is an enzyme that breaks down starch into sugars during dough processing, feeding yeast and driving gas production.
Its concentration in the grain increases when moisture levels are high in the final weeks before harvest, particularly during prolonged wet conditions.
1️⃣ 𝙒𝙝𝙖𝙩'𝙨 𝙩𝙝𝙚 𝙁𝙖𝙡𝙡𝙞𝙣𝙜 𝙉𝙪𝙢𝙗𝙚𝙧 (𝙁𝙉)?
It is a standardized test used to assess the alpha-amylase activity in flour, which is crucial for ensuring optimal fermentation, dough handling, and final product quality.
The test measures the viscosity of a flour-water suspension, indirectly indicating the level of alpha-amylase activity present in the flour.
2️⃣ 𝙃𝙤𝙬 𝙩𝙝𝙚 𝙏𝙚𝙨𝙩 𝙒𝙤𝙧𝙠𝙨
A slurry of flour and water is heated in a boiling water bath while being stirred for 60 seconds. After stirring, the stirrer is released and allowed to fall under gravity. The time (in seconds) it takes for the stirrer to descend to a defined point is recorded as the Falling Number;
- 𝗟𝗼𝘄 𝗙𝗡 (≤𝟮𝟬𝟬): Indicates high alpha-amylase activity. The starch is rapidly broken down, reducing paste viscosity and causing the stirrer to fall quickly.
These results are usually symptomatic of sprout-damaged grain and can lead to sticky doughs, poor loaf volume, and gummy crumbs.
- 𝗛𝗶𝗴𝗵 𝗙𝗡 (≥𝟯𝟱𝟬): Indicates low enzymatic activity. The paste remains thick, resisting the stirrer’s fall. Flour may require supplementation with maltogenic or fungal amylase to improve fermentation and final product quality.
- The minimum theoretical FN is 60 seconds, which includes the stirring phase.
- An 𝗶𝗱𝗲𝗮𝗹 𝗙𝗮𝗹𝗹𝗶𝗻𝗴 𝗡𝘂𝗺𝗯𝗲𝗿 for most breadmaking flours lies between 𝟮𝟱𝟬–𝟮𝟴𝟬 𝘀𝗲𝗰𝗼𝗻𝗱𝘀. This range provides a balance sufficient enzymatic activity to support yeast fermentation (by generating maltose) without compromising dough structure or causing excessive dextrin formation, which can affect slicing and shelf life.
#bakingquality #flourtesting #breadscience #enzymeactivity
👉 💬 Any experiences to share with us?? - We’d love to hear your story!
Sources: lnkd.in/dTbC4qkK
https://lnkd.in/dus-5rvh
https://lnkd.in/d_XMwZz2
https://lnkd.in/dNEXynRv
https://www.linkedin.com/mwlite/feed/posts/bakery-industry-insider_bakingquality-flourtesting-breadscience-activity-7310590117520322560-IS0x?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=%F0%9D%98%BC%F0%9D%99%A1%F0%9D%99%A5%F0%9D%99%9D%F0%9D%99%96%2D%F0%9D%98%BC%F0%9D%99%A2%F0%9D%99%AE%F0%9D%99%A1%F0%9D%99%96%F0%9D%99%A8%F0%9D%99%9A%20%F0%9D%98%BC%F0%9D%99%98%F0%9D%99%A9%F0%9D%99%9E%F0%9D%99%AB%F0%9D%99%9E%F0%9D%99%A9%F0%9D%99%AE%3A%20%F0%9D%99%8F%F0%9D%99%9D%F0%9D%99%9A%20%F0%9D%99%81%F0%9D%99%96%F0%9D%99%A1%F0%9D%99%A1%F0%9D%99%9E%F0%9D%99%A3%F0%9D%99%9C%20%F0%9D%99%89%F0%9D%99%AA%F0%9D%99%A2%F0%9D%99%97%F0%9D%99%9A%F0%9D%99%A7%0A%0AAs%20we%20know,lnkd.in/dNEXynRv
نشاط الألفا-أميليز: رقم السقوط (Falling Number)
كما نعلم، فإن الألفا-أميليز هو إنزيم يقوم بتكسير النشا إلى سكريات خلال عملية تحضير العجينة، مما يغذي الخميرة ويساهم في إنتاج الغاز.
يزداد تركيزه في الحبوب عندما تكون مستويات الرطوبة مرتفعة في الأسابيع الأخيرة قبل الحصاد، وخاصةً خلال الفترات الطويلة من الظروف الرطبة.
1️⃣ ما هو رقم السقوط (Falling Number - FN)؟
هو اختبار معياري يُستخدم لتقييم نشاط إنزيم الألفا-أميليز في الدقيق، وهو أمر بالغ الأهمية لضمان تخمير مثالي، وسهولة التعامل مع العجين، وجودة المنتج النهائي.
يقيس الاختبار لزوجة معلق من الدقيق والماء، مما يعطي مؤشراً غير مباشر على مستوى نشاط الألفا-أميليز الموجود في الدقيق.
2️⃣ كيف يعمل الاختبار؟
يتم تسخين خليط من الدقيق والماء في حمام ماء مغلي مع التحريك لمدة 60 ثانية. بعد ذلك، يُترك المحرّك ليسقط بفعل الجاذبية. ويتم تسجيل الزمن (بالثواني) الذي يستغرقه المحرّك للنزول إلى نقطة محددة، ويُعرف هذا الزمن باسم رقم السقوط (Falling Number).
FN منخفض (≤200): يشير إلى نشاط مرتفع لإنزيم الألفا-أميليز. يتم تكسير النشا بسرعة، مما يؤدي إلى انخفاض لزوجة العجينة وسقوط المحرّك بسرعة. غالباً ما تكون هذه النتائج دليلاً على تلف الحبوب بسبب الإنبات، وقد تؤدي إلى عجائن لزجة، وحجم رغيف ضعيف، وفتات مطاطي.
FN مرتفع (≥350): يشير إلى نشاط إنزيمي منخفض. تبقى العجينة كثيفة، مما يقاوم سقوط المحرّك. في هذه الحالة، قد يتطلب الدقيق إضافة إنزيمات مثل الأميليز المالتي أو الفطري لتحسين عملية التخمير وجودة المنتج النهائي.
الحد الأدنى النظري لرقم السقوط هو 60 ثانية، ويشمل ذلك مرحلة التحريك.
رقم السقوط المثالي لمعظم أنواع دقيق الخبز يتراوح بين 250–280 ثانية. هذا النطاق يوفر توازناً مناسباً لنشاط إنزيمي يدعم تخمير الخميرة (من خلال إنتاج المالتوز) دون التأثير سلباً على بنية العجينة أو التسبب في تكوّن مفرط للدكسترين، مما قد يؤثر على تقطيع الخبز ومدة صلاحيته .
