عندما يكون البيكنج باودر أو بيكربونات الصوديوم (البايكنج صودا) منتهيي الصلاحية ... خبز ثقيل وكثيف
مشاركات: 9271
If you are new here and you are a beginner or aspiring baker, save this; you'll probably need it.
There is nothing to say here; the attached image is self-explanatory.
Actually, there's something I'd like to add.
You see, when your baking powder or soda is expired, your cake will most likely come out as the one labelled "no leaveners."
So keep that in mind just in case you ever bake and it comes out dense and heavy.
Either your baking powder or soda is expired or you forgot to add them while preparing the batter.
As usual, I hope this helps.
Note:
The only fa!led cake in the picture is the one labeled "No Leaveners."
There's no recommended combination or a better one; it all depends on how the recipe you are using was developed.
Some recipes call for baking powder only, and that's totally fine.
Some call for baking soda, and that's okay so long as there's an acid (vinegar, lemon juice, or cream of tartar) in the ingredients to activate the baking soda.
While some recipes were developed to use both baking powder and soda, that's totally fine too.
So it all boils down to what I always advise: "Stick to the specifics of your chosen recipe."
Always follow your recipes.
Don't add, remove, or substitute any ingredient unless you know what you are doing or are experimenting.
Doing any of those will definitely alter the result in one way or another.
https://www.linkedin.com/mwlite/feed/update/urn:li:activity:7322485806323941378#:~:text=If%20you%20are,way%20or%20another.
إذا كنت جديدًا هنا، وكنت مبتدئًا أو طباخًا طموحًا في مجال المخبوزات، فاحفظ هذه المعلومات؛ من المحتمل أنك ستحتاج إليها.
لا يوجد الكثير لقوله هنا؛ فالصورة المرفقة تشرح نفسها بنفسها.
في الواقع، هناك شيء أود إضافته.
أنت ترى، عندما يكون البيكنج باودر أو بيكربونات الصوديوم (البايكنج صودا) منتهيي الصلاحية، فمن المرجح أن تخرج كعكتك كما هو موضح في الكعكة الموسومة بـ "بدون مواد رافعة".
لذا تذكّر هذا في حال قمت بخبز شيء ما وخرج ثقيلاً وكثيفًا.
إما أن البيكنج باودر أو البيكنج صودا لديك منتهيي الصلاحية، أو أنك نسيت إضافتهما أثناء تحضير الخليط.
كالعادة، آمل أن يكون هذا مفيدًا.
ملاحظة:
الكعكة الفاشلة الوحيدة في الصورة هي التي وُسمت بـ "بدون مواد رافعة".
لا توجد تركيبة موصى بها أو تركيبة أفضل من الأخرى؛ فالأمر كله يعتمد على كيفية تطوير الوصفة التي تستخدمها.
بعض الوصفات تتطلب فقط البيكنج باودر، وهذا مقبول تمامًا.
وبعض الوصفات تستخدم البيكنج صودا، وهذا جيد ما دام هناك حمض (كالخل، عصير الليمون، أو كريم التارتار) ضمن المكونات لتفعيل البيكنج صودا.
بينما طُورت بعض الوصفات لاستخدام كل من البيكنج باودر والبيكنج صودا، وهذا مقبول أيضًا.
لذا، الأمر في النهاية يعود لما أكرره دائمًا: "التزم بتفاصيل الوصفة التي اخترتها."
اتبع الوصفات دائمًا.
لا تضف، تحذف، أو تستبدل أي مكون إلا إذا كنت تعرف ما تفعله أو كنت تجرب عمدًا.
فعل أي من هذه الأمور سيؤثر بالتأكيد على النتيجة بطريقة أو بأخرى.
