معايير جودة القمح تؤثر بشكل كبير على كفاءة الطحن، وجودة الدقيق، وهوامش الربح 👌🏻
مرسل: السبت مايو 10, 2025 6:19 pm
Wheat quality parameters matter to milling efficiency, flour quality and profit margins are given in the following:
🌾 1. Moisture Content (08-12%)
🔹 Why it matters:
Ideal moisture ensures proper tempering and efficient separation of bran and endosperm.
Too low = brittle kernels, excessive bran breakage → lower flour yield.
Too high = spoilage risk, storage issues, and risk of microbial growth.
💰 Impact on Profit Margin:
1) Efficient milling = less energy + higher yield = more flour from the same grain.
2) Avoids losses due to spoilage or rejected grain.
💪 2. Protein Content (10–14%)
🔹 Why it matters:
Determines end-product quality (bread vs pastry).
Mills need to blend wheats to hit target protein levels for different flour types.
1) Higher-protein wheat can be sold at a premium.
2) Accurate blending prevents overuse of expensive high-protein grain.
🍞 3. Gluten Quality (GlutenIndex / WetGluten)
🔹 Why it matters:
Strong gluten = good dough elasticity, volume, and gas retention.
Poor gluten = weak doughs, more customer complaints, lower satisfaction.
1) Strong gluten allows for wider market targeting (e.g., industrial bakeries).
2) Reduces the need for additives to compensate for weak dough.
🌾 4. TestWeight (Hectoliter Weight)
🔹 Why it matters:
High test weight means more endosperm and flour per kg.
Low test weight wheat often has shriveled kernels = more bran, less flour.
1) Directly affects flour extraction rate.
2) High test weight = better flour yield = more product with same cost.
🔬 5. Falling Number (250-350 sec)
🔹 Why it matters:
Indicates sprout damage. Low falling number = high alpha-amylase → sticky dough and poor bread quality.
Very important for baking performance.
1) Sprouted grain often gets discounted or rejected by buyers.
2) Prevents reputation damage from bad flour performance.
🧯 6. Kernel Hardness
🔹 Why it matters:
Hard wheat = better for bread; soft wheat = ideal for cakes and biscuits.
Affects milling behavior, energy consumption and flour particle size.
1) Right wheat type = less energy waste, lower wear on rollers.
2) Enables product diversification (breads, biscuits, noodles).
🌟 7. Starch Content & Quality
🔹 Why it matters:
Starch makes up about 70–75% of the wheat kernel and is the main component of flour.
Damaged starch (mechanical breakdown during milling) is crucial; a moderate amount improves water absorption and fermentation but too much can cause stickiness and processing issues.
1) High-quality starch = better flour functionality, especially for products like bread and noodles.
2) Optimal starch damage can increase water absorption, which increases dough yield.
3) Too much starch damage = sticky dough, slower production, more waste.
#Milling #Quality #Baking #Wheat #Flour"
https://www.linkedin.com/mwlite/feed/posts/husnain-hasan-4139471b5_wheat-quality-parameters-activity-7320430500806868996-ok6-?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=%23Wheat%20%23quality%20%23parameters,Wheat%20%23Flour
معايير جودة القمح تؤثر بشكل كبير على كفاءة الطحن، وجودة الدقيق، وهوامش الربح. وفيما يلي توضيح لتلك المعايير وأهميتها:
🌾 1. محتوى الرطوبة (08-12%)
🔹 لماذا هو مهم:
الرطوبة المثالية تضمن ترطيبًا مناسبًا للحبوب وفصلًا فعالًا بين النخالة والاندوسبرم (اللب الداخلي).
الرطوبة المنخفضة جدًا تؤدي إلى تفتت الحبوب بسهولة، مما يسبب تكسيرًا مفرطًا للنخالة وبالتالي تقليل كمية الدقيق الناتج.
الرطوبة المرتفعة جدًا تؤدي إلى خطر التلف، مشاكل في التخزين، وزيادة احتمالية نمو الكائنات الدقيقة.
💰 الأثر على هامش الربح:
الطحن الفعال يعني استهلاك طاقة أقل وزيادة في الإنتاجية = المزيد من الدقيق من نفس كمية الحبوب.
تجنّب الخسائر الناتجة عن تلف الحبوب أو رفضها من قبل المشترين.
💪 2. محتوى البروتين (10–14%)
🔹 لماذا هو مهم:
يحدد جودة المنتج النهائي (مثل الخبز مقابل المعجنات).
تحتاج المطاحن إلى خلط أنواع مختلفة من القمح للوصول إلى مستويات البروتين المطلوبة لكل نوع من أنواع الدقيق.
القمح ذو المحتوى العالي من البروتين يُباع بسعر أعلى.
الخلط الدقيق يمنع الإفراط في استخدام القمح مرتفع السعر.
🍞 3. جودة الجلوتين (مؤشر الجلوتين / الجلوتين الرطب)
🔹 لماذا هو مهم:
الجلوتين القوي يعني مرونة جيدة للعجين، وحجم أفضل، واحتباس جيد للغاز أثناء التخمير.
الجلوتين الضعيف يؤدي إلى عجائن ضعيفة، وزيادة الشكاوى من العملاء، وانخفاض في رضا المستهلكين.
الجلوتين القوي يسمح باستهداف أسواق أوسع مثل المخابز الصناعية.
يقلل الحاجة إلى إضافة محسنات أو إضافات لتعويض ضعف العجين.
🌾 4. الوزن الإختباري (الوزن الهكتوليتر)
🔹 لماذا هو مهم:
الوزن الاختباري المرتفع يشير إلى كمية أكبر من الاندوسبرم والدقيق في كل كيلوغرام من القمح.
القمح ذو الوزن المنخفض يحتوي غالبًا على حبوب منكمشة = نسبة أكبر من النخالة ونسبة أقل من الدقيق.
يؤثر مباشرة على معدل استخلاص الدقيق.
الوزن الاختباري العالي يعني استخلاصًا أفضل = منتج أكثر بتكلفة ثابتة.
🔬 5. رقم السقوط (250-350 ثانية)
🔹 لماذا هو مهم:
يشير إلى مدى تلف الحبوب بسبب الإنبات. الرقم المنخفض يعني نشاط عالٍ لإنزيم الألفا أميليز، مما يؤدي إلى عجائن لزجة وجودة خبز رديئة.
يُعتبر مؤشرًا بالغ الأهمية في أداء الدقيق في الخَبز.
الحبوب المنبتة غالبًا ما تُباع بسعر منخفض أو تُرفض من قبل المشترين.
يحمي من الإضرار بسمعة الشركة بسبب ضعف أداء الدقيق.
🧯 6. صلابة الحبة
🔹 لماذا هو مهم:
القمح الصلب يُفضل للخبز، بينما القمح الطري مثالي للكعك والبسكويت.
تؤثر الصلابة على سلوك الطحن، استهلاك الطاقة، وحجم جزيئات الدقيق.
استخدام النوع المناسب من القمح يقلل من استهلاك الطاقة ويقلل من تآكل آلات الطحن.
يمكّن من تنويع المنتجات مثل الخبز، البسكويت، والمكرونة.
🌟 7. محتوى النشا وجودته
🔹 لماذا هو مهم:
يشكل النشا حوالي 70-75% من حبة القمح، وهو المكون الأساسي للدقيق.
النشا المحطم (بسبب الكسر الميكانيكي أثناء الطحن) له أهمية كبيرة؛ كمية معتدلة منه تحسّن امتصاص الماء والتخمير، لكن زيادته تؤدي إلى مشاكل مثل لزوجة العجين وصعوبات في المعالجة.
النشا عالي الجودة يعزز من أداء الدقيق، خاصة في منتجات مثل الخبز والمكرونة.
الضرر الأمثل للنشا يزيد من امتصاص الماء، مما يرفع من كمية العجين المنتَج.
الضرر الزائد يؤدي إلى عجائن لزجة، بطء في الإنتاج، وزيادة في الفاقد.
