تحطم النشا في طحن الدقيق ... Starch Damage in Flour Milling
مرسل: الثلاثاء مايو 27, 2025 8:12 pm
🔍 What is Starch Damage?
Starch damage occurs when starch granules are physically broken during the milling of wheat.
It is primarily influenced by the hardness of the wheat kernel and the intensity of the milling process.
Damaged starch plays a critical role in determining the functional properties of flour, such as water absorption, dough characteristics, and baking performance.
🎯 Importance of Starch Damage
✅ Functional Benefits:
Increased WaterAbsorption:
1) Damaged starch granules can absorb 2–4 times more water than intact ones.
2) This is beneficial in bread making where high water absorption is desired.
Improved DoughPerformance:
1) Supports better gas retention and gluten development, leading to stronger dough and larger loaf volume.
2) Enhances fermentation stability.
Enzyme Accessibility:
1) Provides more surface area for amylase enzymes to act, producing sugars that feed yeast and improve browning.
Better Baking Results:
1) Improves crumb softness, loaf volume, and crust color in bread.
2) However, excessive starch damage can cause sticky dough and poor crumb texture.
📏 Standard Values for StarchDamage
1) Cake/pastry flour 2.0–4.0% Low absorption for tender products
2) All-purpose flour 4.0–6.0% General use with balanced characteristics
3) Bread flour 6.0–9.0% High absorption and strength for bread
🔧 Starch damage levels are adjusted during milling to suit the target flour application.
⚙️ Interaction with Kernel Hardness
HardWheat:
1) Has a tough endosperm, requiring more force to mill.
2) Results in higher starch damage.
3) Commonly used for bread and high-strength flours.
SoftWheat:
1) Milder, friable endosperm that breaks easily.
2) Leads to lower starch damage.
3) Ideal for cake and pastry flours.
Hard wheat High 6–10% (starch damage)
Soft wheat Low 2–5% (starch damage)
🧪 Interaction with FallingNumber (FN)
1) The Falling Number test measures alpha-amylase activity, which breaks down starch into sugars.
2) Starch damage does not directly affect FN but amplifies the effect of existing alphaAmylase.
🔁 Effect Summary:
More damaged starch = More substrate for alpha-amylase.
If alpha-amylase is present, the starch liquefies faster → lower FN.
Low starch damage = Higher viscosity → higher FN.
Conditions:
High starch damage + high enzyme Very low FN
High starch damage + low enzyme Moderate FN
Low starch damage Higher FN
Thanks for reading 📚
#FlourMilling #WheatQuality #GrainScience #MillingTechnology
#WheatProcessing #KernelHardness #BakingScience #DoughProperties
#BreadMaking #CrumbStructure #WaterAbsorption #LoafVolume
#EnzymeActivity #StarchDamage #DamagedStarch
#AlphaAmylase #EnzymaticActivity #StarchHydrolysis #FunctionalFlour
#SproutDamage #FNTest #WheatTesting #MillingQualityControl #BreadFlour #CakeFlour #PastryFlour #HighProteinFlour
#LowProteinFlour"
https://www.linkedin.com/mwlite/feed/?pwa=noCache#:~:text=%23StarchDamage%20in%20%23FlourMilling,HighProteinFlour%0A%23LowProteinFlour
🔍 ما هو تحطم النشا؟
يحدث تحطم النشا عندما تنكسر حبيبات النشا بشكل فيزيائي أثناء عملية طحن القمح.
يتأثر بشكل أساسي بصلابة حبة القمح وشدة عملية الطحن.
يلعب النشا المحطم دورًا حاسمًا في تحديد الخصائص الوظيفية للدقيق، مثل امتصاص الماء، وخصائص العجين، وأداء الخَبز.
🎯 أهمية تحطم النشا
✅ الفوائد الوظيفية:
زيادة امتصاص الماء:
يمكن لحبيبات النشا التالفة امتصاص كمية من الماء تعادل 2 إلى 4 أضعاف الحبيبات السليمة.
هذا مفيد في صناعة الخبز حيث يُرغب في امتصاص عالي للماء.
تحسين أداء العجين:
يدعم الاحتفاظ بالغاز وتطور الغلوتين بشكل أفضل، مما يؤدي إلى عجين أقوى وحجم رغيف أكبر.
يعزز استقرار التخمير.
سهولة وصول الإنزيمات:
يوفر مساحة سطحية أكبر لتعمل عليها إنزيمات الأميليز، مما ينتج سكريات تُغذي الخميرة وتحسن من التحمير (لون القشرة).
نتائج خبز أفضل:
يحسن من نعومة الفُتات (اللب الداخلي للرغيف)، حجم الرغيف، ولون القشرة.
مع ذلك، فإن تحطم النشا المفرط قد يؤدي إلى عجين لزج وملمس داخلي سيئ للرغيف.
📏 القيم القياسية لتحطم النشا:
دقيق الكيك / المعجنات: 2.0 – 4.0% → امتصاص منخفض للماء يناسب المنتجات الطرية
الدقيق متعدد الاستخدامات: 4.0 – 6.0% → استخدام عام بخصائص متوازنة
دقيق الخبز: 6.0 – 9.0% → امتصاص عالي ومتانة مناسبة للخبز
يتم تعديل مستويات تحطم النشا أثناء الطحن لتناسب الاستخدام المستهدف للدقيق.
⚙️ التفاعل مع صلابة الحبة:
القمح الصلب:
يحتوي على سويداء صلبة، ويتطلب قوة أكبر للطحن.
يؤدي إلى تحطم نشا أعلى.
يُستخدم عادة في دقيق الخبز والدقيق عالي القوة.
القمح الطري:
يحتوي على سويداء هشة وسهلة الانكسار.
يؤدي إلى تحطم نشا أقل.
مثالي لدقيق الكيك والمعجنات.
نوع القمحمستوى تحطم النشاالقمح الصلبعالٍ (6–10%)القمح الطريمنخفض (2–5%)
🧪 التفاعل مع اختبار رقم السقوط (Falling Number):
يقيس اختبار رقم السقوط نشاط إنزيم ألفا-أميليز، الذي يقوم بتفكيك النشا إلى سكريات.
لا يؤثر تحطم النشا مباشرة على رقم السقوط، لكنه يضخم تأثير ألفا-أميليز الموجود.
🔁 ملخص التأثير:
كلما زاد تحطم النشا → زاد الركيزة (السطح المتاح) لألفا-أميليز.
إذا كان الألفا-أميليز موجودًا، يتحلل النشا بشكل أسرع → رقم سقوط أقل.
تحطم نشا منخفض → لزوجة أعلى → رقم سقوط أعلى.
الظروف:
تحطم نشا عالي + إنزيم عالي → رقم سقوط منخفض جدًا
تحطم نشا عالي + إنزيم منخفض → رقم سقوط معتدل
تحطم نشا منخفض → رقم سقوط أعلى
HardWheat:
SoftWheat:
🔁 Effect Summary:
Conditions:
#LowProteinFlour"
🔍 ما هو تحطم النشا؟
🎯 أهمية تحطم النشا
✅ الفوائد الوظيفية:
زيادة امتصاص الماء:
تحسين أداء العجين:
نتائج خبز أفضل:
القمح الصلب:
القمح الطري:
🔁 ملخص التأثير:
الظروف:
