Most KPIs in manufacturing aren’t wrong.
They’re just misunderstood, misused, or misaligned.
Credit to Angad Singh. Give him a follow
Here’s how to fix that:
1/ OEE
– Misused as a benchmark instead of a diagnostic tool
→ Use it to find bottlenecks, not to chase 100%
2/ First Pass Yield
– Misinterpreted as a pure quality metric
→ Always pair it with rework data for full context
3/ Downtime
– Often tracked, rarely categorized
→ Split into planned vs unplanned & then go deeper -reason codes-
4/ Scrap Rate
– Used in isolation
→ Relate it to production volume and trends over time
5/ Cycle Time
– Teams chase faster cycles
→ Instead, focus on consistency and takt time alignment
6/ Lead Time
– Understood only as delivery time
→ Include every touchpoint, from raw material to finished product
7/ Throughput
– Taken as an output metric
→ It’s also a signal for process flow health
8/ Changeover Time
– Seen as “something to reduce”
→ Use SMED principles to reduce waste, not cut corners
9/ Capacity Utilization
– More ≠ better
→ Balance with actual demand and takt time
10/ Inventory Turnover
– Misjudged without a benchmark
→ Find the right rate for your product mix — not just “higher”
11/ MTBF -Mean Time Between Failures-
– Tracked without root causes
→ Always contextualize with operator, part, and process data
12/ Overall Labor Effectiveness -OLE-
– Sounds complex, becomes ignored
→ Break into Availability, Performance, Quality, simplify and share
___
After 300+ Gemba Walks and $2.5M+ in documented savings, we've distilled everything that works into one FREE playbook, Gemba Moonwalker.
Learn how to turn every observation into action and build a problem-solving culture that doesn't wait for you.
Grab your copy → https://lnkd.in/d3usW_Xh"
https://www.linkedin.com/mwlite/feed/posts/gembadojo_most-kpis-in-manufacturing-arent-wrong-activity-7410024084970967040-zBnY?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=Most%20KPIs%20in,lnkd.in/d3usW_Xh
معظم مؤشرات الأداء الرئيسية (KPIs) في التصنيع ليست خاطئة.
لكن المشكلة أنها تُساء فَهمها، أو يُساء استخدامها، أو لا تكون متوافقة مع الهدف.
إليك كيفية تصحيح ذلك:
1/ OEE (الفعالية الكلية للمعدات)
– يُساء استخدامه كمؤشر مقارنة Benchmark بدلًا من كونه أداة تشخيص
→ استخدمه لاكتشاف الاختناقات، وليس لمطاردة نسبة 100٪
2/ First Pass Yield (نسبة المرور من أول مرة)
– يُساء تفسيره كمؤشر جودة بحت
→ اربطه دائمًا ببيانات إعادة التشغيل أو الإصلاح للحصول على الصورة الكاملة
3/ Downtime (التوقفات)
– غالبًا ما يتم تسجيله، ونادرًا ما يتم تصنيفه
→ قسّمه إلى توقفات مخططة وغير مخططة، ثم تعمق أكثر باستخدام رموز أسباب التوقف
4/ Scrap Rate (نسبة الهالك)
– يُستخدم بشكل منفصل
→ اربطه بحجم الإنتاج واتجاهات الأداء عبر الزمن
5/ Cycle Time (زمن الدورة)
– الفرق تلاحق تقليل زمن الدورة
→ الأفضل التركيز على الثبات والاتساق، والتوافق مع زمن التكت (Takt Time)
6/ Lead Time (زمن الإنجاز الكلي)
– يُفهم فقط على أنه زمن التسليم
→ يجب أن يشمل كل نقاط التلامس، من المادة الخام حتى المنتج النهائي
7/ Throughput (معدل الإنتاج أو التدفق)
– يُنظر إليه كمؤشر ناتج فقط
→ لكنه أيضًا إشارة على صحة تدفق العملية
8/ Changeover Time (زمن التغيير أو الإعداد)
– يُنظر إليه على أنه “شيء يجب تقليله”
→ استخدم مبادئ SMED لتقليل الفاقد، وليس لتجاوز الخطوات أو قطع الزوايا
9/ Capacity Utilization (استغلال الطاقة الإنتاجية)
– المزيد لا يعني دائمًا الأفضل
→ وازنه مع الطلب الفعلي وزمن التكت
10/ Inventory Turnover (معدل دوران المخزون)
– يُساء الحكم عليه بدون مرجع أو معيار
→ ابحث عن المعدل المناسب لتشكيلة منتجاتك، وليس فقط “الأعلى”
11/ MTBF (متوسط الزمن بين الأعطال)
– يتم تتبعه دون تحليل الأسباب الجذرية
→ اربطه دائمًا ببيانات المشغل، وقطع الغيار، والعملية
12/ Overall Labor Effectiveness - OLE (الفعالية الكلية للعمالة)
– يبدو معقدًا فيتم تجاهله
→ قسّمه إلى: الإتاحة، الأداء، الجودة — وبسّطه وشاركه مع الفريق.
تعلّم كيف تحوّل كل ملاحظة إلى إجراء عملي، وكيف تبني ثقافة حل مشكلات لا تنتظر وجودك.
معظم مؤشرات الأداء الرئيسية (KPIs) في التصنيع ليست خاطئة ... Most KPIs in manufacturing aren’t wrong
- مشاركات: 9294
