U4GM Strategy Notes for Arc Raiders Milestone Farming
مرسل: الثلاثاء يونيو 23, 2026 10:56 am
If you want to move fast in the Converging Paths event, start with the basics and keep your eyes on ARC Raiders BluePrints while you're in raid, because wandering off for random scraps is how people waste half their night.
Read the project like a shopping listThe Converging Paths Project isn't really about fighting. It's about noticing what the game wants from you, then not getting distracted by shiny loot in the wrong place. People always say they'll "just run one quick raid," then they come back empty-handed and annoyed. Been there. The smart move is to check the current stage before you deploy, then build the whole run around those items.
That means you should know 1. what's required now. 2. how many pieces you still need. 3. whether two objectives can be done on the same route. That little bit of prep saves a ton of time. Honestly, it also cuts down on those dumb moments where you extract with the wrong stuff and realise you basically did nothing.
Stop treating every encounter like a duelThis event rewards extraction, not ego. If you've already got event materials on you, don't go hunting fights just because some guy wants to stare at you from a rooftop. Get what you need, stay alive, and leave. It sounds boring, but boring wins here. You'll progress faster by surviving three clean raids than by trying to flex in one messy one.
A lot of players make the same mistake: they keep pushing deeper because there's "probably one more chest." That's how backpacks fill up with junk and the good stuff gets left behind. Keep your route tight. Grab the event items, ignore the trash, and extract before the raid starts feeling like a bad idea.
Use your inventory like it actually mattersInventory space is the whole game during this project. If your bag's a mess, the run's already getting harder for no reason. I'd rather leave with fewer normal mats than lose the exact item I came for because I stuffed my pack like I was moving house.
1. Carry healing, but don't overpack it.
2. Keep open slots for project materials.
3. Drop low-value junk once you've got the target item.
4. Upgrade backpack space when you can.
Those four habits sound simple, but they save raids. They also make long farming sessions way less annoying. Nobody enjoys digging through a full bag while their extraction timer is ticking down.
Stack objectives whenever the map lets youThe real speed boost comes from combining tasks. If one deployment can tick off two project steps, that's way better than doing them one by one. High-value zones usually have enough overlap to make this happen, especially if you already know the map flow and where players tend to avoid or camp.
Keep an eye on your route, not just the nearest marker. When you move with purpose, the event starts feeling less like a grind and more like a pattern you can repeat. That's where the time gets shaved off. Not from raw luck. Just from fewer wasted steps.
Don't sleep on the smaller rewardsOne nice thing about the project is that every milestone gives you something useful. You're not stuck waiting forever for the final payout. You get crafting materials, event progress items, cosmetics, Raider Coins, and that kind of stuff along the way. It keeps the whole thing moving, which helps when the grind starts to drag a bit.
And yeah, if you're trying to speed up your own progression outside the event loop, ARC Raiders BluePrints for sale can fit into a broader plan without making every raid feel like a chore.
