Arc Raiders U4GM: Marano Station Cache Location
مرسل: السبت يونيو 27, 2026 9:44 am
Market Correction is one of those Arc Raiders quests that looks simple on paper, then turns into a messy little sprint the moment you land. If you've got the right route in mind, though, it's a fast job, and the rewards are worth the detour into the Buried City. The quest also lines up neatly with the rest of Tian Wen's cache-hunting chain, so once you know where to go, you can knock it out without much fuss and even pick up ARC Raiders Items along the way if the run stays quiet.
The target sits near Marano Station in the northwestern Outskirts of Buried City. Don't overthink it. You're not searching inside the station proper. The cache is outside, tucked between the station structure and the Su Durante Warehouses, usually near a wall and the platform side. A lot of players waste time checking the wrong cluster of canisters, which is fair enough because the props look almost identical. The trick is to stick to the outer edge of the map, keep your eyes on the long building line, and ignore the busy center unless you really feel like fighting for no reason.
What actually matters in the raid
People get hung up on the wording, but the quest flow is pretty direct once you're there. You locate the cache, then sabotage it in the same run. No extra turn-in, no weird pickup chain, and no need to drag loot home just to make the quest count. That means a Free Loadout makes sense if you want to save your better gear for something riskier. It's one of those missions where the smart play is boring, and boring is good.
Move around the map edge instead of cutting through central Buried City.
Check the canister group by the station-side wall, not the obvious one first.
Interact once to identify the cache, then again to sabotage it.
If you want a clean exit, head toward the Northern Station after the objective is done.
Most players will feel the same thing here: the hard part is not the interaction, it's getting there without burning time or ammo. Keep your route simple. Use cover. Don't pick fights just because a bot wanders too close. Tian Wen's quests usually reward patience more than firepower, and this one is no different. Even the loot reward leans practical, with a silencer, a compensator, and a light mag upgrade that fit a steady, low-noise setup.
If you're after the smoothest finish, treat Market Correction like a quick in-and-out job. Go in light, stick to the outskirts, and don't linger once the sabotage is done. If the extraction window looks messy, you can still walk away knowing the objective is complete, which is exactly why this quest feels so manageable compared with the rest of Buried City's chaos. And if you're stocking up between runs, ARC Coins can make the whole loop feel a lot less painful when you're ready to prep for the next raid.
