رقم السقوط Falling Number ضروري لتقييم جودة دقيق القمح من خلال قياس نشاط إنزيم ألفا-أميليز، الذي يؤثر على أداء الخبز
مشاركات: 9270
The 𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫 𝐭𝐞𝐬𝐭 is crucial for evaluating the quality of 𝐰𝐡𝐞𝐚𝐭 𝐟𝐥𝐨𝐮𝐫 by measuring the activity of the enzyme 𝐚𝐥𝐩𝐡𝐚-𝐚𝐦𝐲𝐥𝐚𝐬𝐞, which affects baking performance.
𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫 𝐓𝐞𝐬𝐭 𝐟𝐨𝐫 𝐖𝐡𝐞𝐚𝐭 𝐅𝐥𝐨𝐮𝐫:
𝐏𝐮𝐫𝐩𝐨𝐬𝐞: To determine if wheat has been damaged by 𝐩𝐫𝐞-𝐡𝐚𝐫𝐯𝐞𝐬𝐭 𝐬𝐩𝐫𝐨𝐮𝐭𝐢𝐧𝐠, which increases alpha-amylase levels and can negatively impact flour quality.
𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫 𝐓𝐞𝐬𝐭 𝐏𝐫𝐨𝐜𝐞𝐬𝐬
𝟏. 𝐒𝐚𝐦𝐩𝐥𝐞 𝐏𝐫𝐞𝐩𝐚𝐫𝐚𝐭𝐢𝐨𝐧:Mix 7 grams of wheat flour with 25 milliliters of distilled water to form a slurry.
𝟐. 𝐇𝐞𝐚𝐭𝐢𝐧𝐠 𝐚𝐧𝐝 𝐒𝐭𝐢𝐫𝐫𝐢𝐧𝐠: Place the test tube in a Falling Number machine in a boiling water bath and stir to mix the slurry.
𝟑. 𝐆𝐞𝐥𝐚𝐭𝐢𝐧𝐢𝐳𝐚𝐭𝐢𝐨𝐧: Heat the mixture until the starch gelatinizes, allowing alpha-amylase to break down starch into sugars.
𝟒. 𝐌𝐞𝐚𝐬𝐮𝐫𝐢𝐧𝐠 𝐓𝐢𝐦𝐞:Release the stirrer and record the time it takes to fall through the slurry as the Falling Number.
𝐈𝐧𝐭𝐞𝐫𝐩𝐫𝐞𝐭𝐚𝐭𝐢𝐨𝐧
𝐇𝐢𝐠𝐡 𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫: A longer fall time indicates low enzyme activity and less starch breakdown, suggesting good quality wheat that is not sprouted.
𝐋𝐨𝐰 𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫: A shorter fall time indicates high enzyme activity, signaling sprouted wheat where excessive alpha-amylase breaks down starch too quickly.
The total time reflects alpha-amylase activity in the sample, with higher Falling Numbers indicating less activity and lower Falling Numbers indicating more activity.
𝐊𝐞𝐲 𝐑𝐞𝐬𝐮𝐥𝐭𝐬:
𝐇𝐢𝐠𝐡 𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫 (>𝟑𝟎𝟎 𝐬𝐞𝐜𝐨𝐧𝐝𝐬): Indicates low alpha-amylase activity, meaning high-quality, non-sprouted wheat, suitable for bread-making.
𝐋𝐨𝐰 𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫 (<𝟐𝟎𝟎 𝐬𝐞𝐜𝐨𝐧𝐝𝐬): Indicates high alpha-amylase activity due to sprouting, leading to poor baking quality.
𝐈𝐦𝐩𝐨𝐫𝐭𝐚𝐧𝐜𝐞 𝐨𝐟 𝐭𝐡𝐞 𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫 𝐓𝐞𝐬𝐭:
𝐁𝐚𝐤𝐢𝐧𝐠 𝐐𝐮𝐚𝐥𝐢𝐭𝐲: Ensures the right balance of enzymes for optimal dough strength and volume in baked products.
𝐂𝐨𝐧𝐬𝐢𝐬𝐭𝐞𝐧𝐜𝐲: Allows millers to reject poor-quality wheat, maintaining uniformity in flour production.
𝐄𝐜𝐨𝐧𝐨𝐦𝐢𝐜 𝐈𝐦𝐩𝐚𝐜𝐭: Prevents customer complaints and financial losses linked to low-quality baked goods.
𝐂𝐨𝐧𝐭𝐞𝐱𝐭 𝐢𝐧 𝐏𝐚𝐤𝐢𝐬𝐭𝐚𝐧:
Due to climatic conditions like monsoon rains leading to sprouted wheat, the 𝐅𝐚𝐥𝐥𝐢𝐧𝐠 𝐍𝐮𝐦𝐛𝐞𝐫 𝐭𝐞𝐬𝐭 is vital for Pakistani millers. It ensures the use of high-quality wheat, helping maintain standards in flour production.
#Fallingnumber #perten #bastak #aegic #ibrar #grains #cereal #wheat #bread #baking #flour #flourmill #iaom #qc #alpha #enzyme #mill #buhler
https://www.linkedin.com/mwlite/feed/posts/ibrar-hussain-b5a794211_fallingnumber-perten-bastak-activity-7252188336692314112-nOfc?utm_source=share&utm_medium=member_android#:~:text=The%20%F0%9D%90%85%F0%9D%90%9A%F0%9D%90%A5%F0%9D%90%A5%F0%9D%90%A2%F0%9D%90%A7%F0%9D%90%A0%20%F0%9D%90%8D%F0%9D%90%AE%F0%9D%90%A6%F0%9D%90%9B%F0%9D%90%9E%F0%9D%90%AB%20%F0%9D%90%AD%F0%9D%90%9E%F0%9D%90%AC%F0%9D%90%AD%20is%20crucial,mill%20%23buhler
اختبار Falling Number ضروري لتقييم جودة دقيق القمح من خلال قياس نشاط إنزيم ألفا-أميليز، الذي يؤثر على أداء الخبز.
اختبار Falling Number لدقيق القمح:
الهدف: تحديد ما إذا كان القمح قد تعرض للتلف بسبب الإنبات قبل الحصاد، مما يزيد من مستويات ألفا-أميليز ويؤثر سلبًا على جودة الدقيق.
خطوات اختبار Falling Number:
1. تحضير العينة: يتم خلط 7 جرامات من دقيق القمح مع 25 مليلتر من الماء المقطر لتكوين خليط سائل.
2. التسخين والتحريك: توضع أنبوبة الاختبار في جهاز Falling Number في حمام ماء يغلي ويتم تحريك الخليط.
3. التجبن: يُسخن الخليط حتى تتجبن النشويات، مما يسمح لألفا-أميليز بتكسير النشا إلى سكريات.
4. قياس الزمن: يتم تحرير المحرّك وتسجيل الوقت الذي يستغرقه للمرور عبر الخليط باعتباره الرقم الناتج عن اختبار Falling Number.
تفسير النتائج:
رقم Falling Number مرتفع: يشير الوقت الطويل إلى نشاط منخفض لإنزيم ألفا-أميليز وتكسير أقل للنشويات، مما يشير إلى قمح جيد الجودة غير منبت.
رقم Falling Number منخفض: يشير الوقت القصير إلى نشاط عالي لإنزيم ألفا-أميليز، مما يدل على قمح منبت يتم فيه تكسير النشا بسرعة كبيرة.
الوقت الإجمالي يعكس نشاط إنزيم ألفا-أميليز في العينة؛ الأرقام المرتفعة تعني نشاطًا أقل، والأرقام المنخفضة تعني نشاطًا أكبر.
النتائج الرئيسية:
رقم Falling Number مرتفع (>300 ثانية): يدل على نشاط منخفض لألفا-أميليز، مما يعني قمحًا عالي الجودة غير منبت، مناسب لصنع الخبز.
رقم Falling Number منخفض (<200 ثانية): يدل على نشاط عالي لألفا-أميليز بسبب الإنبات، مما يؤدي إلى جودة خبز ضعيفة.
أهمية اختبار Falling Number:
جودة الخبز: يضمن التوازن الصحيح للإنزيمات لتحقيق قوة العجين المثلى وحجم المنتجات المخبوزة.
الثبات: يسمح للمطاحن برفض القمح منخفض الجودة، مما يحافظ على التوحيد في إنتاج الدقيق.
الأثر الاقتصادي: يمنع الشكاوى من العملاء والخسائر المالية المرتبطة بالمنتجات المخبوزة منخفضة الجودة.
السياق في باكستان:
نظرًا للظروف المناخية مثل الأمطار الموسمية التي تؤدي إلى إنبات القمح، فإن اختبار Falling Number مهم لمطاحن باكستان لضمان استخدام قمح عالي الجودة، مما يساعد على الحفاظ على معايير إنتاج الدقيق.
