Flour Moisture Analysis عمل اختبار رطوبة الدقيق
The simple air-oven method is sufficiently accurate for the routine analysis of flour moisture at the flour mill or bakery. The procedure involves heating a small sample of flour (~2g) for 1 hr at 266˚F (130˚C + 1˚C) and taking the loss in weight as the moisture content.
The moisture content of the flour is important for two reasons. First, the higher the moisture content, the lower the amount of dry solids in the flour. Flour specifications usually limit the flour moisture to 14% or less. It is in the miller’s interest to hold the moisture as close to 14% as possible. Secondly, flour with greater than 14% moisture is not stable at room temperature. Organisms naturally present in the flour will start to grow at high moistures, producing off odors and flavors.
