الفرق بين صوامع الصلب /الصوامع المعدنية والصوامع الخرسانية
الصوامع
من خلال هذه المقالة سنحلل الفرق بين صوامع الصلب /الصوامع المعدنية والصوامع الخرسانية
Silos
Through this article we’ll analyze the difference between steel and concrete silos
1. Steel silos
Small & large bins built of steel sheets, and exclusively built in round shape.
Advantages:
- short erection time and easier to install accessories like doors, ladders, samplers, etc.
- all parts are manufactured in a factory, so the quality of the sheets can be totally controlled
- can be used immediately after erection
- lower investment
- can built as a flat bottom (with a sweep auger) or with outlet cone (self-emptying)
- better grains aeration/chilling
- more flexible, they have better behavior in case of earthquake
- do not require the soil to be as firm in order to support the weight of the structure, they can be built on land that doesn’t have the higher load-bearing capacity needed for concrete
- they don't crack or suffer from a shap-related malfunction
In view of the fact that steel sheet is a very good heat conductor, this construction material is not in all cases suitable to provide for safe storage conditions. The difference in temperature during day and night time or changing weather conditions is immediately transmitted onto the the bin content and onto the air of the empty space in the bin. On account of this heating up followed by cooling, condensation may occur.
Note that during supervision, should pay attention for airtight, sheets should be properly bolted and sealed
2. Reinforced concrete silos
This construction material is suitable for bins of any shape and size; therefore it is possible to utilize the available ground surface at 100% by building what called a Star bins between the rounded silos
Higher investment than the steel silos, field supervision plays a really serious role in concrete silos: more people working on site, longer period of commissioning
The wall thickness is naturally as compared to sheet steel silos considerable bigger, which is slightly negatively influencing the total holding capacity.
Reinforced concrete is a considerably better insulator than steel, and in addition, has a porous structure i. e. reinforced concrete can give away or absorb moisture. Should however in a reinforced concrete bin, in spite of bad heat conductibility, condensed water occur, the same would be mainly absorbed by the bin walls.
The 14 cm reinforced concrete silo wall has an insulation effect which is approx. 1000 times better than the one of a 5 mm steel sheet bin wall.
Advantages:
- all shapes of bins are possible
- 100% of surface ground can be utilized
- no corrosion, not susceptible to rust
- good insulation against temperature fluctuations
- low maintenance costs
- better results when fumigation process
- stronger structure, low risk of silo's collapse
- concrete silos are only more suitable when the space is really limited as they can be taller than steel silos
In conclusion, the right choice is the one that fits in your infrastructure strategy
الصوامع
1. الصوامع الفولاذية / المعدنية
صناديق صغيرة وكبيرة مصنوعة من ألواح الصلب ، ومبنية حصريًا بشكل دائري.
مزايا:
- قصر وقت الانتصاب وسهولة تركيب الملحقات مثل الأبواب والسلالم وأخذ العينات وما إلى ذلك.
- يتم تصنيع جميع الأجزاء في المصنع بحيث يمكن التحكم في جودة الألواح بشكل كامل
- يمكن استخدامه بعد الانتصاب مباشرة
- استثمار أقل
- يمكن بناؤها كقاعدة مسطحة (مع اوجير مسح) أو بمخروط مخرج (تفريغ ذاتي)
- تهوية / تبريد الحبوب بشكل أفضل
- أكثر مرونة ، لديهم سلوك أفضل في حالة الزلزال
- لا تتطلب أن تكون التربة متماسكة من أجل دعم وزن الهيكل ، فيمكن بناؤها على أرض لا تتمتع بقدرة تحمل أعلى للخرسانة
- لا يتشققون أو يعانون من خلل متعلق بأشكال حالات العسر الشديد
نظرًا لحقيقة أن الألواح الفولاذية هي موصل جيد جدًا للحرارة ، فإن مواد البناء هذه ليست مناسبة في جميع الحالات لتوفير ظروف تخزين آمنة. ينتقل الاختلاف في درجات الحرارة أثناء النهار والليل أو تغير الظروف الجوية على الفور إلى محتوى الحاوية وإلى هواء المساحة الفارغة في الحاوية. بسبب هذا التسخين المتبوع بالتبريد ، قد يحدث تكثيف.
لاحظ أنه أثناء الإشراف ، يجب الانتباه إلى محكم الإغلاق ، يجب أن تكون الألواح مثبتة ومختومة بشكل صحيح
2. صوامع الخرسانة المسلحة
مواد البناء هذه مناسبة للصناديق من أي شكل وحجم ؛ لذلك من الممكن الاستفادة من سطح الأرض المتاح بنسبة 100٪ من خلال بناء ما يسمى صناديق Star بين الصوامع المستديرة
استثمار أعلى من الصوامع الفولاذية ، يلعب الإشراف الميداني دورًا جادًا حقًا في الصوامع الخرسانية: يعمل المزيد من الأشخاص في الموقع ، وفترة تشغيل أطول
تكون سماكة الجدار بشكل طبيعي مقارنة بصوامع الألواح الفولاذية أكبر بكثير ، مما يؤثر سلبًا قليلاً على قدرة الاستيعاب الإجمالية.
تعتبر الخرسانة المسلحة عازلًا أفضل بكثير من الفولاذ ، بالإضافة إلى أنها تتمتع ببنية مسامية. ه. يمكن للخرسانة المسلحة أن تتخلص من الرطوبة أو تمتصها. ومع ذلك ، في حالة وجود ماء مكثف في صندوق خرساني مقوى ، على الرغم من التوصيل الحراري السيئ ، فسيتم امتصاص نفس الشيء بشكل أساسي بواسطة جدران الصندوق.
جدار الصومعة الخرساني المسلح بطول 14 سم له تأثير عزل تقريبًا. أفضل 1000 مرة من جدار حاوية الصفائح الفولاذية 5 مم.
مزايا:
- كل أشكال الصوامع والخزانات ممكنة
- يمكن استخدام 100٪ من سطح الأرض
- لا تآكل ، غير قابل للصدأ
- عزل جيد ضد تقلبات درجات الحرارة
- تكاليف صيانة منخفضة
- نتائج أفضل عند عملية التبخير
- هيكل أقوى ، وانخفاض مخاطر انهيار الصومعة
- تكون الصوامع الخرسانية أكثر ملاءمة فقط عندما تكون المساحة محدودة حقًا لأنها يمكن أن تكون أطول من الصوامع الفولاذية
في الختام ، الخيار الصحيح هو الخيار الذي يناسب استراتيجية البنية التحتية الخاصة بك .
https://www.linkedin.com/posts/ahmad-alsaman-ahmad1988_silos-activity-6987896816751030272-2y_K?utm_source=share&utm_medium=member_desktop
