How to Identify Electric Motor Wear and Failure كيفية التعرف على تآكل وفشل المحرك الكهربائي
www.mechanicalnowledge.com
Published on May 23, 2023
Mechanical Engineering WorldPractical Electric Motor Handbook Pdf Document
Abnormal Noise: Listen for unusual or increased noise levels coming from the motor. Grinding, scraping, or rattling sounds may indicate worn-out bearings, misalignment, or internal damage.
Overheating: Monitor the motor's temperature during operation. Excessive heat can be a sign of various problems, including overloading, insufficient cooling, or insulation breakdown.
Vibrations: Excessive vibrations can be an indicator of motor wear or misalignment. If you notice strong vibrations, it may suggest a need for maintenance or repairs.
Increased Current Draw: Monitor the motor's current draw. If you notice a significant increase in the amount of current it consumes, it could indicate internal problems or mechanical wear.
Course Of Generators And Motors Pdf Document
Reduced Performance: If the motor's performance declines, such as reduced speed, reduced torque, or difficulty starting, it could indicate wear or impending failure.
Electrical Issues: Check for any signs of electrical problems, such as flickering lights, tripped circuit breakers, or blown fuses. These issues may be caused by motor faults or failures.
Insulation Breakdown: Inspect the motor's insulation system for any signs of damage, such as cracks, burns, or discoloration. Insulation breakdown can lead to short circuits and motor failure.
Excessive Bearing Play: Check for any play or looseness in the motor's bearings by attempting to move the motor shaft sideways. Excessive play can indicate bearing wear and may require replacement.
Visual Inspection: Conduct a thorough visual inspection of the motor, looking for signs of damage, corrosion, loose connections, or burnt components. Pay attention to any unusual odors, smoke, or signs of arcing.
Motor Data Analysis: Utilize data logging and analysis tools to monitor the motor's operating parameters over time. Abnormal trends or deviations from the motor's normal performance can help identify wear or impending failure.
For More Information Follow
If you notice any of these signs or suspect motor wear or failure, it is recommended to consult with a qualified electrician or motor technician for a more accurate diagnosis and necessary repairs.
Cpd
https://www.linkedin.com/pulse/how-identify-electric-motor-wear-failure?utm_source=share&utm_medium=member_android&utm_campaign=share_via
يُعد المحرك الكهربائي من الأجزاء الحيوية في العديد من التطبيقات الصناعية والتجارية، ولذلك فإن مراقبته بشكل دوري وتحديد أي علامات على تآكله وفشله يساعد على الحفاظ على أدائه الأمثل وتجنب حدوث توقفات غير متوقعة في الإنتاجية. وفي هذا المقال، سنلقي نظرة على كيفية التعرف على علامات تآكل وفشل المحرك الكهربائي.
1- الضوضاء الغير طبيعية:
استمع الإصغاء إلى المستويات الصوتية غير المعتادة أو المرتفعة الناتجة عن المحرك، يمكن تحديد علامات تآكله وفشله. فإذا سمعت أصواتًا مثل الصرير أو الخراب أو الرنين، فقد يشير ذلك إلى وجود تلف في المحامل أو عدم التواء أو تلف داخلي في المحرك.
2- الحرارة الزائدة:
ينبغي رصد حرارة المحرك أثناء التشغيل، لأن الحرارة الزائدة يمكن أن تشير إلى مشاكل مختلفة، مثل الحمل الزائد، وعدم كفاية التبريد، أو تلف العزل.
3- الاهتزازات الزائدة:
إذا لاحظت اهتزازات قوية غير طبيعية، فقد يشير ذلك إلى تآكل المحرك أو عدم تواءه. وإذا كانت الاهتزازات قوية، فقد يكون هناك حاجة لإجراء عمليات الصيانة والإصلاح اللازمة.
4- زيادة استهلاك التيار:
يجب مراقبة كمية التيار التي يستهلكها المحرك، وإذا لاحظت زيادة كبيرة في كمية التيار، فقد يكون هذا إشارة إلى مشاكل داخلية أو تآكل ميكانيكي.
5- تراجع الأداء:
إذا لاحظت تراجعًا في أداء المحرك، مثل تقليل السرعة أو العزم أو صعوبة البدء، فقد يشير ذلك إلى تآكل أوفشل المحرك الكهربائي. وينبغي اتخاذ إجراءات الصيانة والإصلاح اللازمة في هذه الحالة.
وفي النهاية، يجب علينا التأكد من أن المحرك الكهربائي يتلقى الصيانة الدورية المناسبة، وأن أي علامات على تآكله وفشله تتم مراجعتها وإصلاحها في الوقت المناسب. وهذا سيساعد على الحفاظ على أدائه الأمثل وضمان عمره الافتراضي الطويل.
المصدر: Practical Electric Motor Handbook Pdf Document
23 مايو 2023
استمع إلى مستويات الضوضاء غير المعتادة أو الارتفاعات الناتجة عن المحرك. يمكن أن تشير اصوات الثريى أو الخراب أو الرنين إلى تآكل البلى ، أو عدم تناسق أو تلف داخلي في المحرك.
2- الحرارة الزائدة:
راقب حرارة المحرك أثناء التشغيل. يمكن أن تشير الحرارة الزائدة إلى مشاكل مختلفة، بما في ذلك الحمل الزائد، وعدم كفاية التبريد، أو تلف العزل.
يمكن أن تشير الاهتزازات الزائدة إلى تآكل المحرك أو عدم تواءه. إذا لاحظت اهتزازات قوية غير طبيعية، فقد يكون هناك حاجة لإجراء عمليات الصيانة والإصلاح اللازمة.
راقب كمية التيار التي يستهلكها المحرك. إذا لاحظت زيادة كبيرة في كمية التيار، فقد تشير إلى وجود مشاكل داخلية أو تآكل ميكانيكي.
5- تراجع الأداء:
إذا لاحظت تراجعًا في أداء المحرك، مثل تقليل السرعة أو العزم أو صعوبة البدء، فقد يكونهذا إشارة إلى تآكل أو فشل المحرك الكهربائي.
6- المشاكل الكهربائية:
تحقق من وجود أي علامات على المشاكل الكهربائية، مثل تقطيع الأضواء أو إنقطاع التيار الكهربائي أو الصمامات المنصهرة. يمكن أن تسبب هذه المشاكل أخطاء أو فشل في المحرك.
7- تلف العزل:
تفحص نظام العزل في المحرك للبحث عن أي علامات على التلف، مثل الشقوق أو الحروق أو التلوين. يمكن أن يؤدي تلف العزل إلى حدوث اختصارات كهربائية وفشل المحرك.
9- لعبة/حركة البلى الزائدة:
تحقق من وجود أي لعب أو فضول في بلى المحرك عن طريق محاولة تحريك عمود المحرك جانبيًا. يمكن أن يشير اللعب الزائد إلى تآكل المحمل وقد يتطلب الأمر استبداله.
10- التفتيش البصري:
أجرِ تفتيشًا بصريًا شاملاً للمحرك، وابحث عن علامات الضرر أو التآكل أو الاتصالات الرخوة أو المكونات المحترقة. وافتح عينيك لأي روائح غير عادية أو دخان أو علامات للقوس الكهربائي.
11- تحليل بيانات المحرك:
استخدم أدوات تسجيل البيانات والتحليل لمراقبة معلمات تشغيل المحرك على مر الزمن. يمكن أن تساعد الاتجاهات الغير طبيعية أو الانحرافات عن الأداء الطبيعي للمحرك على التعرف على التآكل أو الفشل المحتمل.
إذا لاحظت أيًا من هذه العلامات أو اشتبهت في تآكل أو فشل المحرك، يُنصح بالتشاور مع فني كهربائي مؤهل أو فني محركات للحصول على تشخيص أكثر دقة والإصلاح اللازم.
