كومبيكلينر - كومبى كلينر combicleaner كومبي كلينر
A " combicleaner " is a type of machine used in the wheat cleaning section of a flour mill. It is designed to remove impurities from
wheat before it is further processed into flour.
The combicleaner is a highly efficient machine that uses a combination of air and sieves to remove impurities such as dirt, dust, stones, and other foreign materials from the wheat. The machine consists of a series of screens, air channels, and fans that work together to separate the wheat from the impurities.
The wheat is fed into the combicleaner through a hopper, and as it passes through the machine, it is subjected to a series of screens and air channels that remove the impurities. The screens on the machine are made of different sizes of mesh to allow the wheat to pass through while holding back the impurities. The airflow is adjusted to ensure that the wheat is thoroughly cleaned without damaging the grains.
After passing through the combicleaner , the wheat is further processed into flour through a series of rollers and sifters. The use of a combicleaner in the wheat cleaning section of a flour mill is essential to ensure that the final product is of high quality and free from impurities.
Regular maintenance and cleaning of the combicleaner are necessary to ensure that it continues to operate efficiently. This includes regular inspection of the screens and air channels, cleaning of the fans and other components, and lubrication of moving parts. Any damaged or worn components should be replaced promptly to avoid downtime and ensure the continued efficient operation of the machine.
" combicleaner " هو نوع من الآلات المستخدمة في قسم تنظيف القمح في مطحنة الدقيق. وهو مصمم لإزالة الشوائب من القمح قبل معالجته بشكل أكبر لتحويله إلى دقيق.
الـ " combicleaner " هو آلة فعالة للغاية تستخدم مزيجًا من الهواء والغرابيل لإزالة الشوائب مثل الأتربة والغبار والحجارة والمواد الأجنبية الأخرى من القمح. تتكون الآلة من سلسلة من الشرائح sieves وقنوات الهواء والمراوح التي تعمل معًا لفصل القمح عن الشوائب.
يتم تغذية القمح في الـ " combicleaner " من خلال قمع، وبمروره عبر الآلة يتعرض لسلسلة من الشرائح sieves وقنوات الهواء التي تزيل الشوائب. تتكون الشرائح sieves على الآلة من أحجام مختلفة من الشبك للسماح للقمح بالمرور من خلالها بينما تحجز الشوائب. يتم تعديل تدفق الهواء لضمان تنظيف القمح بشكل كامل دون إتلاف الحبوب.
بعد مرور القمح عبر الـ " combicleaner "، يتم معالجته بشكل أكبر لتحويله إلى دقيق من خلال سلسلة من الأسطوانات والغرابيل. يعتبر استخدام الـ " combicleaner " في قسم تنظيف القمح في مطحنة الدقيق ضروريًا لضمان أن المنتج النهائي ذو جودة عالية وخالٍ من الشوائب.
تتطلب الصيانة والتنظيف الدوري لـ " combicleaner " لضمان استمرار تشغيله بكفاءة. ويشمل ذلك فحص الشرائح sieves وقنوات الهواء بشكل دوري، وتنظيف المراوح والمكونات الأخرى، وتزييت الأجزاء المتحركة. يجب استبدال أي مكونات تالفة أو متآكلة على الفور لتجنب توقف العمل وضمان استمرارية عمل الآلة بكفاءة.
Combi-Cleaner
The Combi-Cleaner unit performs four operations in a single machine:
· separates grains according to the particle size
· sorts grains according to the specific gravity
· as a de-stoner to remove the stone, glass bits, metal, etc
· as an aspirator to remove lightweight impurities
· as a classifier to grade the main product
This machine features a space-saving design with a single housing for the five
process operations. The central aspiration connection can combine with this
machine to separate the low-density particles such as dust, hulls, chaff and
shriveled kernels. Experience gained in this field confirms that this machine
achieves outstanding performance characteristics and ease of operation.
The Combi-Cleaner is suited to modern processing applications where
space-saving and optimized performance is called for.
يقوم جهاز "Combi-Cleaner" بأربع عمليات في آلة واحدة:
· فصل الحبوب حسب حجم الجسيمات
· فرز الحبوب حسب الكثافة النوعية
· إزالة الحجر وقطع الزجاج والمعدن وما إلى ذلك
· كمجرشة لإزالة الشوائب الخفيفة الوزن
· كمصنف لتصنيف المنتج الرئيسي
تتميز هذه الآلة بتصميم يوفر المساحة مع وجود وحدة واحدة لخمسة عمليات مختلفة. يمكن أن يتم اقتران الاتصال المركزي للشفط مع هذه الآلة لفصل الجزيئات ذات الكثافة المنخفضة مثل الغبار والقش وقشور الحبوب والحبوب المتقشرة. تؤكد الخبرة المكتسبة في هذا المجال أن هذه الآلة تحقق خصائص أداء متميزة وسهولة في التشغيل.
تناسب آلة "Combi-Cleaner" التطبيقات الحديثة للمعالجة حيث يتم استدعاء توفير المساحة والأداء المحسّن.
Combi-Cleaner
•The combi-cleaner combines several cleaning principles into one machine.
•The top screener portion removes impurities by size.
•The middle deck separates wheat by density into two fractions (high and low density).
•The bottom deck removes stones and mud.
•The tail end aspirator removes light impurities with air currents.
يجمع الـ "Combi-Cleaner" بين عدة مبادئ للتنظيف في آلة واحدة.
• يزيل الجزء العلوي من الغرابيل الشوائب حسب الحجم.
• يفصل الطبقة الوسطى القمح حسب الكثافة إلى جزئين (كثافة عالية وكثافة منخفضة).
• يزيل الطبقة السفلية الحجارة والطين.
• يزيل الجزء الخلفي للمجرشة الشوائب الخفيفة الوزن بتيارات الهواء.
Combination Machine Combi-Cleaner
Re: كومبيكلينر - كومبى كلينر combicleaner كومبي كلينر
## شرح ميكانيكية عمل MTKB combicleaner مع نظام إعادة تدوير الهواء من Buhler:
MTKB combicleaner هو نظام تنظيف فعّال مصمم لتنظيف الحبوب من الشوائب المختلفة.
يتكون النظام من:
* وحدة تنظيف مسبق:
* تُستخدم لإزالة الشوائب الكبيرة مثل الحجارة والعصي.
* وحدة تنظيف هوائي:
* تُستخدم لإزالة الشوائب الخفيفة مثل القش والغبار.
* نظام إعادة تدوير الهواء:
* يُستخدم لتحسين كفاءة عملية التنظيف.
ميكانيكية العمل:
1. تُمرر الحبوب عبر وحدة التنظيف المسبق:
* حيث يتم إزالة الشوائب الكبيرة بواسطة غربال اهتزازي.
2. تُنقل الحبوب إلى وحدة التنظيف الهوائي:
* حيث يتم تعريضها لتيار هواء قوي يُزيل الشوائب الخفيفة.
3. يتم إعادة تدوير الهواء المستخدم في عملية التنظيف:
* من خلال نظام إعادة تدوير الهواء.
4. يتم تنظيف الهواء من الشوائب قبل إعادة استخدامه:
* من خلال مرشح هواء.
مميزات نظام MTKB combicleaner:
* كفاءة عالية في تنظيف الحبوب:
* يُزيل النظام جميع أنواع الشوائب تقريبًا.
* استهلاك منخفض للطاقة:
* يُعد النظام أكثر كفاءة من أنظمة تنظيف الحبوب التقليدية.
* سهولة التشغيل والصيانة:
* يُعد النظام سهل الاستخدام والصيانة.
نظام MTKB combicleaner هو حل مثالي لتنظيف الحبوب في مختلف المجالات، بما في ذلك:
* مطاحن الدقيق:
* يُستخدم النظام لتنظيف الحبوب قبل طحنها.
* صناعة الأعلاف:
* يُستخدم النظام لتنظيف الحبوب قبل خلطها مع مكونات أخرى.
* صناعة التخمير:
* يُستخدم النظام لتنظيف الحبوب قبل تخميرها.
## ميكانيكية فصل الشوائب من حبوب القمح باستخدام الكومبيكلينر:
يعتمد الكومبيكلينر على مزيج من التقنيات الميكانيكية والهوائية لفصل الشوائب من حبوب القمح.
أولاً، يتم تمرير الحبوب عبر غربال اهتزازي لإزالة الشوائب الكبيرة مثل الحجارة والعصي.
ثانياً، يتم تعريض الحبوب لتيار هواء قوي يُزيل الشوائب الخفيفة مثل القش والغبار.
ثالثاً، يتم استخدام تقنية تسمى "التصنيف الهوائي" لفصل حبيبات القمح عن الشوائب ذات الكثافة المختلفة.
في التصنيف الهوائي، يتم تمرير الحبوب عبر تيار هواء صاعد يتم التحكم في سرعته بدقة.
تُعلق حبيبات القمح في تيار الهواء بينما تسقط الشوائب ذات الكثافة المختلفة على الأرض.
رابعاً، يتم استخدام جهاز شفط لإزالة الشوائب المتبقية من الحبوب.
خامساً، يتم تنظيف الهواء المستخدم في عملية التنظيف من الشوائب قبل إعادة استخدامه.
مميزات استخدام الكومبيكلينر لفصل الشوائب من حبوب القمح:
* كفاءة عالية:
* يُزيل الكومبيكلينر جميع أنواع الشوائب تقريبًا.
* دقة عالية:
* يُمكن للكومبيكلينر فصل حبيبات القمح عن الشوائب ذات الكثافة المماثلة.
* سهولة الاستخدام:
* يُعد الكومبيكلينر سهل الاستخدام والصيانة.
* يُعد الكومبيكلينر أكثر كفاءة من الطرق التقليدية لفصل الشوائب.
يُعد الكومبيكلينر أداة قيّمة لتحسين جودة حبوب القمح المستخدمة في مختلف المجالات، بما في ذلك:
* مطاحن الدقيق:
* يُستخدم الكومبيكلينر لتنظيف حبوب القمح قبل طحنها.
* صناعة الأعلاف:
* يُستخدم الكومبيكلينر لتنظيف حبوب القمح قبل خلطها مع مكونات أخرى.
* صناعة التخمير:
* يُستخدم الكومبيكلينر لتنظيف حبوب القمح قبل تخميرها.
