يلعب محتوى الجليادين دورًا أساسيًا في قوة العجين .... Gliadin content plays a key role in dough strength
مرسل: السبت نوفمبر 23, 2024 7:24 pm
يلعب محتوى الجليادين دورًا أساسيًا في قوة العجين بسبب تأثيره على شبكة الجلوتين.
Gliadin content plays a key role in #dough strength because of its influence on the #gluten network.
Let me simplify the mechanism for you. 🌾✨
1. Glutenin's Role:
🔗 Glutenin,
particularly high-molecular-weight (HMW) glutenin, provides elasticity and strength to the gluten network.
->It forms a highly cross-linked structure through disulfide bonds and non-covalent interactions, acting as the skeletal framework of the dough.
2. Gliadin's Role:
🌐 Gliadin
is primarily responsible for extensibility and viscosity in the dough.
->However, due to its spherical structure and lack of extensive disulfide bonding, it does not contribute to the same degree of network formation as glutenin.
✅ ❌ Impact of Gliadin on Dough Strength:
1. Positive Contribution at Optimal Levels:
✔️ Gliadin interacts with glutenin via non-covalent forces, helping to fill the network and contribute to extensibility.
->This balance between gliadin and glutenin is crucial for desirable dough properties.
2. Negative Effects at High Levels:
⚠️ As indicated by Melnyk et al. (2012), an excessive amount of gliadin can:
❌ Hinder the formation of a strong glutenin network by diluting the concentration of glutenin molecules available for cross-linking.
❌ Decrease the compactness and strength of the overall gluten network.
❌ Make the dough more prone to mechanical stress, such as the formation and recrystallization of ice in frozen storage, which can exacerbate gluten macropolymer (GMP) depolymerization.
💡⚖️Practical Implications:
1. Doughs with higher gliadin content
are less suited for applications requiring high strength💪.
Such as rich recipes or frozen dough❄️, as they may exhibit reduced gas retention and structural integrity.
2. Balancing the gliadin-to-glutenin ratio
is crucial for optimizing dough performance.
Strong bread flours 🍞typically have higher glutenin content relative to gliadin, while softer flours
used in
cakes🍰 or
pastries 🎂
may have a higher gliadin-to-glutenin ratio to enhance extensibility and tenderness.
#rheology #breadmaking #Grainar
https://www.linkedin.com/mwlite/feed/posts/dimitrios-argyriou-1a38251b6_dough-gluten-rheology-activity-7265986995577909248-GNHG?utm_source=share&utm_medium=member_android#:~:text=Gliadin%20content%20plays,breadmaking%20%23Grainar
اسمح لي بتبسيط الآلية لك:
1. دور الجلوتينين:
🔗 الجلوتينين، وخاصة الجلوتينين ذو الوزن الجزيئي المرتفع (HMW)، يوفر مرونة وقوة لشبكة الجلوتين (المرونة).
-> يشكل بنية مترابطة للغاية من خلال روابط ثنائية الكبريتيد ( S-S disulfide bonds) وتفاعلات غير تساهمية، ليعمل كالإطار الهيكلي للعجين.
2. دور الجليادين:
🌐 الجليادين مسؤول أساسًا عن القابلية للتمدد (المطاطية) واللزوجة في العجين.
-> ومع ذلك، بسبب بنيته الكروية وعدم وجود روابط ثنائية الكبريتيد واسعة النطاق، فإنه لا يساهم بدرجة كبيرة في تكوين الشبكة مثل الجلوتينين.
✅ ❌ تأثير الجليادين على قوة العجين:
1. المساهمة الإيجابية عند المستويات المثلى:
✔️ يتفاعل الجليادين مع الجلوتينين عبر قوى غير تساهمية، مما يساعد على ملء الشبكة والمساهمة في القابلية للتمدد.
-> هذا التوازن بين الجليادين والجلوتينين ضروري للحصول على خصائص مرغوبة للعجين.
2. الآثار السلبية عند المستويات العالية:
⚠️ وفقًا لدراسة Melnyk et al. (2012)، فإن الكميات الزائدة من الجليادين يمكن أن:
❌ تعيق تكوين شبكة قوية من الجلوتينين عن طريق تخفيف تركيز جزيئات الجلوتينين المتاحة للترابط.
❌ تقلل من تماسك وقوة شبكة الجلوتين بشكل عام.
❌ تجعل العجين أكثر عرضة للإجهاد الميكانيكي، مثل تكوين وإعادة تبلور الجليد أثناء التخزين المجمد، مما يؤدي إلى تفكك بوليمرات الجلوتين الكبيرة (GMP).
💡⚖️ التطبيقات العملية:
1. العجائن التي تحتوي على مستويات عالية من الجليادين
-> أقل ملاءمة للتطبيقات التي تتطلب قوة عالية 💪، مثل الوصفات الغنية أو العجين المجمد ❄️، حيث قد تعاني من تقليل احتباس الغاز وضعف البنية.
2. تحقيق التوازن بين نسبة الجليادين إلى الجلوتينين
-> أمر ضروري لتحسين أداء العجين.
الدقيق القوي المستخدم في الخبز 🍞 يحتوي عادةً على نسبة أعلى من الجلوتينين مقارنة بالجليادين.
أما الدقيق المستخدم في الكعك 🍰 أو المعجنات 🎂، فيحتوي غالبًا على نسبة أعلى من الجليادين إلى الجلوتينين لتعزيز القابلية للتمدد والنعومة .
Re: يلعب محتوى الجليادين دورًا أساسيًا في قوة العجين .... Gliadin content plays a key role in dough strength
مرسل: السبت نوفمبر 23, 2024 7:49 pm
Their dedication, sleepless nights, and groundbreaking innovations have shaped #wheat #protein #science as we know it today.
Let’s honor them by recognizing and remembering their contributions.
1745 - Jacopo Beccari:
Professor of chemistry at the University of Bologna published a famous description of gluten in De frumento. He separated wheat into two fractions: "amylaceum" (starchlike, soluble in water) and "glutinosum" (insoluble and sticky, similar to proteins).
1773 - Parmentier:
Showed that gluten was soluble in vinegar (acetic acid) and partially in spirits of wine.
1805–1806 - Einhof:
Demonstrated that part of gluten was soluble in alcohol, and similar fractions were present in barley and rye, helping define prolamins.
1819 - Taddei:
Further separated gluten into fractions that were soluble (gliadins) or insoluble (zymon, later called glutenin) in alcohol.
1821–1869 - Gorham, Bizio, Kreusler:
Expanded protein research to maize and oats.
1838 - Mulder and Berzelius:
Proposed the term "protein," meaning "primary substance."
1893 - Osborne and Vorhees:
Published studies on wheat proteins. 1907: Osborne continued his research.
1924 - Osborne's Monograph:
Published The Vegetable Proteins, summarizing his studies.
Osborne's Classification: Concluded that plant proteins were simple and divided them into four types, known as the "Osborne fractions": albumins, globulins, prolamins, and glutelins.
1939 - Bishop:
Noted that extraction of hordein from barley increased with bisulfite, indicating the role of disulfide bonds.
1950 - Foster et al:
Showed that the extractability of zein from maize increased with a reducing agent.
1953–1959 - Lontie et al:
Conducted studies on barley, laying the groundwork for understanding protein solubility.
1959 - Jones et al:
Introduced electrophoresis on starch gel for separating proteins.
1961–1966 - Woychik, Lee, Meredith and Wren:
Developed techniques using starch and polyacrylamide gels, as well as chaotropic agents for better protein separation.
1971–1973 - Sodek, Wilson, Bietz, and Wall:
Found that disulfide bonds influence protein solubility, showing gliadins form intrachain bonds and glutenins form both inter- and intrachain bonds.
1972 - Bietz and Wall: |
Introduced SDS-PAGE, revolutionizing protein separation by molecular weight.
1973 - Wrigley and Shepherd:
Applied two-dimensional electrophoresis (2-DE) to analyze complex protein mixtures.
1983 - Bietz:
Introduced high-performance liquid chromatography (HPLC), significantly improving the precision of protein fraction analysis.
https://www.linkedin.com/posts/dimitrios-argyriou-1a38251b6_wheat-protein-science-activity-7254343414257770497-g7Yx?utm_source=share&utm_medium=member_desktop&trk=feed-detail_comments-list-reply_comment-text
تفانيهم، لياليهم التي قضوها بلا نوم، وابتكاراتهم الرائدة شكلت علم بروتين القمح كما نعرفه اليوم.
لنتذكر ونكرم مساهماتهم التي تركت أثرًا دائمًا.
1745 - جاكوبو بيكاري:
أستاذ الكيمياء في جامعة بولونيا، نشر وصفًا شهيرًا للجلوتين في كتابه De frumento.
فصل القمح إلى جزأين:
"amylaceum" (يشبه النشا، قابل للذوبان في الماء).
"glutinosum" (غير قابل للذوبان ولزج، يشبه البروتينات).
1773 - بارمنتييه:
أظهر أن الجلوتين يذوب في الخل (حمض الأسيتيك) وجزئيًا في الكحول.
1805-1806 - أينهوف:
بيّن أن جزءًا من الجلوتين يذوب في الكحول، وأثبت وجود أجزاء مشابهة في الشعير والشيلم، مما ساعد في تعريف البروليمينات (Prolamins).
1819 - تاداي:
فصل الجلوتين إلى مكونات تذوب في الكحول (الجليادين) وأخرى لا تذوب (زيمن، وسميت لاحقًا الجلوتينين).
1821-1869 - غورام، بيزيو، وكروسلر:
وسعوا أبحاث البروتين لتشمل الذرة والشوفان.
1838 - مولدر وبيرزيليوس:
قدما مصطلح "البروتين"، بمعنى "المادة الأساسية".
1893 - أوزبورن وفورهيز:
نشرا دراسات حول بروتينات القمح.
1907: واصل أوزبورن أبحاثه.
1924 - كتاب أوزبورن:
نشر كتاب The Vegetable Proteins الذي لخص فيه أبحاثه.
تصنيف أوزبورن: خلص إلى أن بروتينات النباتات بسيطة وقسمها إلى أربعة أنواع، عرفت باسم "فئات أوزبورن":
الألبيومينات (Albumins).
الجلوبيولينات (Globulins).
الجلوتيلينات (Glutelins).
1939 - بيشوب:
لاحظ أن استخراج هوردين (Hordein) من الشعير يزداد باستخدام البيسلفيت، مشيرًا إلى دور روابط ثنائي الكبريتيد.
1950 - فوستر وآخرون:
أثبتوا أن قابلية استخراج زين (Zein) من الذرة تزداد باستخدام عامل اختزالي.
1953-1959 - لونتي وآخرون:
أجروا دراسات على الشعير، مهدوا لفهم ذوبانية البروتينات.
1959 - جونز وآخرون:
أدخلوا تقنية الفصل الكهربائي باستخدام هلام النشا لفصل البروتينات.
1961-1966 - وويشيك، لي، ميريديث، ورين:
طوروا تقنيات استخدام هلام النشا والبولي أكريلاميد والعوامل الفوضوية (chaotropic agents) لفصل البروتينات بشكل أفضل.
1971-1973 - سوديك، ويلسون، بيتز، ووال:
أثبتوا أن روابط ثنائي الكبريتيد تؤثر على ذوبانية البروتين.
أظهروا أن الجليادين يشكل روابط داخل السلسلة، بينما يشكل الجلوتينين روابط داخل السلسلة وبين السلاسل.
1972 - بيتز ووال:
قدما تقنية SDS-PAGE، التي أحدثت ثورة في فصل البروتينات حسب الوزن الجزيئي.
1973 - وريجلي وشيبرد:
طبقا الفصل الكهربائي ثنائي الأبعاد (2-DE) لتحليل خلطات البروتين المعقدة.
1983 - بيتز:
أدخل تقنية الكروماتوجرافيا السائلة عالية الأداء (HPLC)، مما حسّن دقة تحليل أجزاء البروتين بشكل كبير.
