حجم الرغيف ... رغم أن نسبة البروتين مهمة .... ولكن الحقيقة التي لا يمكننا تجاهلها .... كمية البروتين ≠ جودة البروتين
Every day, I see too many decisions in milling and baking still relying on a single number:
-> Protein percentage.
🔺 But here’s the truth we can’t afford to ignore:
-> Protein quantity ≠ protein functionality.
->This graph, conceptualized by A. Bijttebier,
makes that distinction crystal clear…
-> Despite having the same % protein,
one cultivar consistently produces significantly higher loaves.
🧪 Let’s decode it:
✅ Cultivar A shows a steeper slope
this means that each incremental % of protein translates into a much larger increase in loaf volume.
✅ Cultivar B, with a flatter slope,
reveals that its protein even at similar levels
cannot form a gluten network capable of sustaining gas retention or oven spring.
📍 Both lines intersect near 8% protein, highlighting a well-established concept:
- Below this level,
protein quality plays a limited role. Bread volume is influenced more by starch gelatinization, batter viscosity, and limited gas expansion.
- Above 8%,
however, gluten network formation becomes the dominant performance factor—and protein quality becomes the differentiator.
🧬 What defines protein quality?
- Glutenins (especially high-molecular-weight subunits) create the elastic backbone of the dough.
- Gliadins add plasticity and extensibility.
- The ability of gluten to form a cohesive, extensible, and gas-retaining network is what translates into actual bread volume.
🔺 This is not theoretical.
➡️ In protein reconstitution studies,
gluten from high-quality flour was combined with starch and solubles from poor-quality flours—yet the loaf volume remained high.
➡️ Gluten protein fraction alone dictated the result.
🧰 Why this matters in practice:
For millers, bakers, breeders, and technologists:
- A flour with 12% protein might perform like a 10% or 14%, depending on gluten quality.
- A regression slope like this gives a fast, data-driven estimate of protein effectiveness—with just one standardized bread test and protein %.
- To complement it:
Use SDS sedimentation, Gluten Index, Frainograph , Mixolab, Alveograph P/L, Extensograph, resistance/extension, and controlled bake tests.
📊 Key Insight:
Bread volume is
a function of protein’s ability to form and sustain a thermomechanically stable gluten matrix. ❗ ❗
#gluten #protein #bread #rheology #Grainar
https://www.linkedin.com/mwlite/feed/posts/dimitrios-argyriou-1a38251b6_milling-baking-gluten-activity-7317759597509804033-lcBp?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=Every%20day%2C%20I,rheology%20%23Grainar
كل يوم، ألاحظ أن هناك عددًا كبيرًا من القرارات في مجالي الطحن والخبز لا تزال تستند إلى رقم واحد فقط:
→ نسبة البروتين.
🔺 لكن إليك الحقيقة التي لا يمكننا تجاهلها:
→ كمية البروتين ≠ وظيفة البروتين.
→ هذا الرسم البياني، الذي تصوره "أ. بيجتبير"، يوضح هذا الفرق بجلاء…
→ فعلى الرغم من أن النسبة المئوية للبروتين متساوية،
إلا أن أحد الأصناف النباتية ينتج أرغفة ذات حجم أعلى بكثير وبشكل منتظم.
🧪 دعونا نفكك هذا المفهوم:
✅ الصنف A يُظهر ميلًا أكثر حدة
وهذا يعني أن كل زيادة طفيفة في نسبة البروتين تُترجم إلى زيادة أكبر بكثير في حجم الرغيف.
✅ الصنف B، بمنحنى أكثر انبساطًا،
يُظهر أن بروتينه، حتى مع وجود نسب متماثلة،
لا يستطيع تكوين شبكة جلوتين قادرة على الاحتفاظ بالغاز أو دعم التمدد في الفرن.
📍 تتقاطع كلا الخطين بالقرب من نسبة بروتين تبلغ 8%، مما يسلط الضوء على مفهوم معروف جيدًا:
تحت هذا المستوى،
تلعب جودة البروتين دورًا محدودًا. إذ يتأثر حجم الخبز بشكل أكبر بعمليات مثل تجلُّت النشا، ولزوجة العجين، والتوسع المحدود للغاز.
لكن فوق 8%،
تصبح عملية تكوين شبكة الجلوتين العامل الأساسي في الأداء—وتصبح جودة البروتين هي العامل الفارق.
🧬 ما الذي يُحدد جودة البروتين؟
الجلوتينينات (وخاصة الوحدات ذات الوزن الجزيئي العالي) تُكوِّن العمود الفقري المرن للعجين.
الجليادينات تُضفي على العجين الليونة والقابلية للتمدد.
قدرة الجلوتين على تكوين شبكة متماسكة، قابلة للتمدد، وقادرة على الاحتفاظ بالغاز—هي ما يُترجم إلى حجم فعلي للرغيف.
🔺 هذا ليس مجرد نظريًا.
➡️ في دراسات إعادة تركيب البروتين،
تم جمع الجلوتين من دقيق عالي الجودة مع النشا والمكونات الذائبة من دقيق منخفض الجودة—ومع ذلك، ظل حجم الرغيف مرتفعًا.
➡️ جزء البروتين الجلوتيني وحده هو الذي حدد النتيجة.
🧰 لماذا هذا مهم عمليًا:
بالنسبة للمطاحن، والخبازين، والمُهجنين، والتقنيين:
قد يُعطي دقيق يحتوي على 12% بروتين أداءً مشابهًا لدقيق يحتوي على 10% أو 14%، وذلك بحسب جودة الجلوتين.
يوفر منحنى الانحدار مثل هذا تقديرًا سريعًا ومرتكزًا على البيانات لكفاءة البروتين—باستخدام اختبار خبز موحّد واحد فقط مع معرفة نسبة البروتين.
ولتعزيز هذا التقييم: استخدم اختبارات مثل ترسيب SDS، ومؤشر الجلوتين، وفرينوجراف، وميكسولاب، وألفيوغراف (P/L)، واختبار التمدد Extensograph، ومقاومة/استطالة العجين، واختبارات خبز محكومة.
📊 الرؤية الأساسية:
حجم الرغيف
هو نتاج لقدرة البروتين على تكوين والحفاظ على شبكة جلوتين مستقرة حراريًا وميكانيكيًا. ❗❗
