تجربة مختلفة لتحليل السبب الجذري ... A Different Root Cause Analysis Experience
What is Root Cause Analysis (RCA)?
RCA is a structured problem-solving method focused on identifying the fundamental cause of problems—not just symptoms—so we can learn and prevent recurrence.
1. Root Cause = Evidence-Based
Root causes are not failure modes or guesses—they must be supported by hard evidence.
RCA team from different departments will ask: Did we gather clues? Talk to people involved? Examine failed parts?
2. RCA is About Learning, Not Blaming
Learn from what went wrong.
Benchmark not just successes, but failures too.
Quote: “You don’t learn about yourself through success, only through failures.” – Wynonna Judd
3. People Make Mistakes – Don’t Punish Them.
Human errors are inevitable—even in the best systems.
RCA should promote learning and safety, not fear or blame.
Encourage open discussion through “amnesty” for mistakes.
4. RCA Has 3 Levels:
Physical Cause – What physically failed?
Human Cause – What did people do or not do?
Latent Cause – What systems, culture, or environment allowed the error?
5. Fixing Isn’t Enough—Analyze Instead
Being good at fixing problems isn’t success—it’s a warning.
Aim to reduce the need for repairs through deep analysis.
Final Thought:
“Root Cause ends when latent causes are exposed. Only then can we truly say we’ve learned from what went wrong.”
https://www.linkedin.com/mwlite/feed/posts/gagan-malik-8b768a2_a-different-root-cause-analysis-experience-activity-7317486301417545728-t2B4?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=A%20Different%20Root,what%20went%20wrong.%E2%80%9D
ما هو تحليل السبب الجذري (RCA)؟
تحليل السبب الجذري هو أسلوب منظم لحل المشكلات يركز على تحديد السبب الأساسي للمشاكل – وليس مجرد الأعراض – وذلك لكي نتعلم ونتجنب تكرارها في المستقبل.
1. السبب الجذري = قائم على الأدلة
الأسباب الجذرية ليست أوضاع فشل أو تخمينات – بل يجب أن تكون مدعومة بأدلة ملموسة.
فريق RCA المكوّن من أقسام مختلفة سيطرح أسئلة مثل: هل جمعنا الأدلة؟ هل تحدثنا مع الأشخاص المعنيين؟ هل فحصنا الأجزاء التالفة؟
2. RCA يتعلق بالتعلم وليس باللوم
يجب أن نتعلم مما حدث من أخطاء.
قارن ليس فقط النجاحات، بل أيضًا الإخفاقات.
اقتباس: "أنت لا تتعلم عن نفسك من خلال النجاح، بل فقط من خلال الفشل." – وينونا جود
3. الناس يخطئون – لا تعاقبهم
الأخطاء البشرية أمر لا مفر منه – حتى في أفضل الأنظمة.
يجب أن يشجع RCA على التعلم والسلامة، لا على الخوف أو اللوم.
شجع النقاش المفتوح من خلال "عفو" عن الأخطاء.
4. تحليل السبب الجذري له 3 مستويات:
السبب المادي – ما الذي فشل من الناحية الفيزيائية؟
السبب البشري – ماذا فعل الناس أو لم يفعلوا؟
السبب الكامن – ما الأنظمة أو الثقافة أو البيئة التي سمحت بحدوث الخطأ؟
5. الإصلاح لا يكفي – بل التحليل هو الأهم
القدرة على إصلاح المشكلات ليست علامة على النجاح – بل على وجود مشكلة مستمرة.
الهدف هو تقليل الحاجة للإصلاح من خلال التحليل العميق.
فكرة ختامية:
"ينتهي تحليل السبب الجذري عندما يتم الكشف عن الأسباب الكامنة. حينها فقط يمكننا القول بأننا تعلمنا حقًا مما حدث."
