التحليل الجذري للأسباب (Root Cause Analysis - RCA) هو عملية منهجية تُستخدم لتحديد السبب الأساسي لمشكلة أو خلل
Root Cause Analysis (RCA) is a systematic process used to identify the fundamental cause of a problem, defect, or non-conformance, rather than just addressing its symptoms. It aims to prevent recurrence by fixing the underlying issue.
Key Steps in RCA:
1. Problem Identification: Clearly define the problem or incident.
2. Data Collection: Gather relevant information and evidence (e.g., when, where, how often it occurs).
3. Cause Identification: Use tools to identify possible root causes:
5 Whys: Ask "why" repeatedly until the root cause is reached.
Pareto Analysis: Focus on causes with the biggest impact (80/20 rule).
Fishbone Diagram (Ishikawa): Categorize potential causes (e.g., Man, Machine, Method, Material).
4. Corrective Actions: Develop and implement solutions that eliminate the root cause.
5. Follow-up: Monitor to ensure the issue doesn’t recur.
How it Works:
Start with a clear statement of the problem. Then ask why that problem happened. For each answer, ask “why” again—until you reach the underlying cause.
Example in a Dairy Setting:
Problem: Spoiled yogurt found during routine quality check.
1. Why is the yogurt spoiled?
→ Because bacteria were found in the product.
2. Why were bacteria present?
→ Because pasteurization was not effective.
3. Why was pasteurization not effective?
→ Because the temperature was lower than required.
4. Why was the temperature low?
→ Because the temperature sensor was faulty.
5. Why was the sensor faulty?
→ Because maintenance was not scheduled.
https://www.linkedin.com/mwlite/feed/posts/john-simiyu-4580b4238_root-cause-analysis-rca-is-a-systematic-activity-7319100645410586624-1FQK?utm_source=share&utm_medium=member_android&rcm=ACoAABG_IYwBEFoQoeYtJNIF1NzAvC8HDe-lKJ4#:~:text=Root%20Cause%20Analysis,was%20not%20scheduled.
التحليل الجذري للأسباب (Root Cause Analysis - RCA) هو عملية منهجية تُستخدم لتحديد السبب الأساسي لمشكلة أو خلل أو عدم تطابق، بدلاً من معالجة الأعراض فقط. يهدف هذا التحليل إلى منع تكرار المشكلة من خلال معالجة السبب الجذري لها.
الخطوات الأساسية في التحليل الجذري للأسباب (RCA):
1. تحديد المشكلة: تحديد وتعريف المشكلة أو الحادث بشكل واضح.
2. جمع البيانات: جمع المعلومات والأدلة ذات الصلة (مثل: متى وأين وكم مرة تحدث المشكلة).
3. تحديد الأسباب: استخدام أدوات مختلفة لتحديد الأسباب الجذرية المحتملة، مثل:
خمس مرات لماذا (5 Whys): طرح سؤال "لماذا؟" بشكل متكرر حتى يتم التوصل إلى السبب الجذري.
تحليل باريتو (Pareto Analysis): التركيز على الأسباب التي لها التأثير الأكبر (قاعدة 80/20).
مخطط عظم السمكة (إيشيكاوا - Fishbone Diagram): تصنيف الأسباب المحتملة ضمن فئات مثل: الإنسان، الآلة، الطريقة، المواد.
4. اتخاذ الإجراءات التصحيحية: تطوير وتنفيذ الحلول التي تستهدف إزالة السبب الجذري للمشكلة.
5. المتابعة: مراقبة الوضع لضمان عدم تكرار المشكلة مرة أخرى.
كيف يعمل التحليل الجذري للأسباب:
يبدأ التحليل ببيان واضح للمشكلة. ثم يُطرح سؤال "لماذا حدثت هذه المشكلة؟"، ولكل إجابة يتم طرح "لماذا؟" مرة أخرى، حتى يتم التوصل إلى السبب الأساسي الكامن وراء المشكلة.
مثال في بيئة إنتاج الألبان:
المشكلة: تم العثور على زبادي فاسد أثناء فحص الجودة الروتيني.
1. لماذا الزبادي فاسد؟
→ لأن هناك بكتيريا في المنتج.
2. لماذا وُجدت البكتيريا؟
→ لأن عملية البسترة لم تكن فعالة.
3. لماذا لم تكن عملية البسترة فعالة؟
→ لأن درجة الحرارة كانت أقل من المطلوب.
4. لماذا كانت درجة الحرارة منخفضة؟
→ لأن مستشعر الحرارة كان معطلاً.
5. لماذا كان المستشعر معطلاً؟
→ لأنه لم يتم جدولة الصيانة له.
